20 Most Recent HP LaserJet 1320 Printer Questions & Answers
Try connecting the printer to a circuit board (one with a circuit breaker) to ensure overvoltage is minimised. Next check that the printer has the appropriate power setting (220v/110v Depending on your area.) Ps- not all fuses are the same , if you have the original 1 look on the adaptor and it will say 220/110V at ?A thats the proper fuse to get ,if you replaced a different fuse (lower rating) it will go out instantly.if the fuse still goes out you will need to ask Hp for a replacement adaptor for your printer.(if none is available you need to either take it to hp (costly) or buy another printer .
Hope it helps
HP LaserJet 1320... | Answered on May 04, 2019
For me worked this:
- Turn off the printer
- Turn on the printer
- Push and mantain pushed the button on the back of the printer (near to USB connector) for 30 seconds.
- Release the button
- With 1 to 3 minutes for DHCP Server (if you have one)
The printer now have a default configuration, if you have a DHCP server your printer now have a IP Address of your DHCP Server's IP pool.
- Print a coniguration page holding down the green button until the attention LED is blinking
- Release it, 3 pages will be printed.
It is done
HP LaserJet 1320... | Answered on Nov 15, 2018
Windows may have eaten its baby again- that is, the driver for that printer.
Open the Control Panel, then Printers and Faxes, delete any listing for that model of printer, make sure the printer is on and connected, then reboot your system. This will force Win to 'find' the printer and install an uncorrupted driver for it.
(=Plug and Pray)
HP LaserJet 1320... | Answered on Oct 16, 2018
Just downloading the PCL5 driver was not enough for my computer. Maybe it is enough for other users' computers. But in addition to downloading the drivers, i had to also download and install the "HP Laserjet 1320 plug and play print driver solution" at the bottom of the driver list. Save the file to your desktop, double-click it and follow instructions to install, then reboot. Then when I checked my printer list, the HP Laserjet 1320 was there. I printed a test page, and now i am good to go. Hope this helps.
HP LaserJet 1320... | Answered on Oct 10, 2018
Go to HP.COM to the drivers and support tab, search for your driver and download
Try changing to a new USB cable
Please check limiters paper in tray 2 to be on A4, letter, depending on paper format. Otherwise you have problems with taking the sheet from tray 2.
HP LaserJet 1320... | Answered on Aug 05, 2018
To reverse an image for iron-on transfers
1. On the File menu in your software application, click Print.
2. Make sure the product is the selected printer.
3. Click the button that opens the Properties dialog box.
Depending on your software application, this button might be called Properties,
Options, Printer Setup, Printer, or Preferences.
4. Click the Features tab.
5. In the Paper Type drop-down list, click More, and then select HP Iron-on Transfer
from the list.
6. If the selected size is not what you want, click an appropriate size in the Size list.
7. Click the Advanced tab.
8. In the Features area, select the Mirror Image checkbox.
9. Click OK, and then click Print or OK in the Print dialog box.
For support call Our Toll-Free 1 888 224 4280
HP LaserJet 1320... | Answered on May 05, 2018
Hi if you says that the paper gets jam at the fuser meeting point than i m sure that registration assembly which register the paper with toner cartridge is not working properly this is internal hardware fault.
It may caused due to faulty pickup assembly too.
There is a small **** manual feed tray try to print using manual feed and check if the problem persists then registration assembly is faulty if the it print fine from manual feed than Tray 2 pickup assembly or pickup roller is faulty.
HP LaserJet 1320... | Answered on Apr 04, 2018
http://h20564.www2.hp.com/hpsc/swd/public/readIndex?sp4ts.oid=410626
HP LaserJet 1320... | Answered on Oct 19, 2017
Try cleaning drum voltage contact
HP LaserJet 1320... | Answered on Sep 21, 2017
Check for a sticking button on the printer itself. The big Green button will produce a test print if pushed. Also try disconnecting it from the wall outlet overnight to reset it.
HP LaserJet 1320... | Answered on Jul 27, 2017
Its indicates attention..1. door open 2. cartridge missed 3. no paper in tray 4. paper jam.
open the door there is notch which pushes the switch check notch broken? reinsert the cartridge check, load paper in tray check paper sensor flag strucked. Lift registration assm plate any paper partials under clean it..
HP LaserJet 1320... | Answered on Feb 28, 2017
More information is needed to answer this. How do you know the registration is unseated or damaged? What have you done so far?
HP LaserJet 1320... | Answered on Jul 29, 2016
download the service manual.....
http://www.manualslib.com/manual/682599/Hp-Laserjet-1160.html#product-LaserJet 1320
HP LaserJet 1320... | Answered on Jul 14, 2016
HP LaserJet 1320 Printer Logo
864 questions posted
Clive
Clive
Thomas F. Schneider
View Most Popular
LaserJet HP
  • LaserJet HP
Most Popular Question
reset hp 1320n factory default
  • Office Equipment & Supplies
