20 Most Recent E-Machines eMachines Desktop PC Questions & Answers
If you are facing issues while updating in windows 10 you are required to read our blog for latest updates each methods explained in blog are sufficient to fix issue
http://bit.ly/2FreOnT
E-Machines... | Answered on Mar 04, 2019
You are right when you say it's really slow when you play games online, 1. The Game server is accessing by you through wires and network devices, so this makes the games slow. If the game is installed in your pc, there's should be no speed problem, 2. Network bandwidth will be accumulated by the game when you run the program, so don't take tension,... we are facing the same problem and it's just normal. There's nothing different. Good luck
E-Machines... | Answered on Jan 23, 2019
Check what is the ipaddress,tried to shut down the laptop and drain flea power.Then check if the laptop can detect wireless connection. Then ping website in command prompt.Try ipconfig /release and then ipconfig /renew. Try connecting wired internet connection to check if issue with operating system or browser or wireless connectivity.
E-Machines... | Answered on Nov 21, 2018
A computer running slow down for many reasons, but most of those boil down to one thing - how do you use it. If you are experiencing this issue, you are not alone, nearly half of the complaints received by computer repair technicians were related to poor system performance or system slow down. Here are the top six reasons why your computer is performing slower. Read this blog to know more https://antivirus.comodo.com/blog/computer-safety/6-reasons-why-pc-running-slow/?af=9557
E-Machines... | Answered on Jul 04, 2018
you need to reinstall chrome because there is a corrupt or missing file needed to remain stable........click here to get it....when ur done make sure you remove all other internet browsers and set chrome as your default...you should be good to go. Good Luck and pls rate this post!! :D
E-Machines... | Answered on May 28, 2018
"Stop: 0x000000A5" error message typically indicates that the computer BIOS is incompatible with the Advanced Configuration and Power Interface (ACPI) standard that is supported in Windows 7. However, this error can also occur because the computer hardware, the peripherals, or the drivers for those devices are incompatible with Windows 7.
Startup Repair from the Windows Recovery Environment (WinRE)
1. Insert the Windows 7 installation disc into the disc drive, and then start the computer.
2. Press a key when the message indicating "Press any key to boot from CD or DVD ...". appears.
3. Select a language, a time and currency, and a keyboard or input method, and then click Next.
4. Click Repair your computer.
5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next.
6. At the System Recovery Options Dialog Box, click on Repair your computer.
7. Click the operating system that you want to repair, and then click Next.
8. In the System Recovery Options dialog box, click Startup Repair.
Refer the following link for more information:
http://windows.microsoft.com/en-US/windows7/What-are-the-system-recovery-options-in-Windows-7
E-Machines... | Answered on Apr 06, 2018
Hardware stores usually sell adhesive rubber pads just look for something that resembles the missing feet on your netbook.
E-Machines... | Answered on Feb 13, 2018
i need help put sound on my computer, and where to go to download a sound device driver
E-Machines... | Answered on Jan 27, 2018
not sure think you need recovery CD,but go to this link it might help you out.. system restore windows xp emachines T3516 Google Search
E-Machines... | Answered on Oct 27, 2017
Try booting it to safe mode and see if it does it there. If it doesn't it seems like it could be software related, if it does do it there it is probably hardware
E-Machines... | Answered on Sep 28, 2017
Hiya,
I have an image for you to look at, and I will need confirmation that this is or is or is not what you are giving reference to.
http://techreport.com/r.x/tyan-tigermpx/power-connectors.jpg
As far as your issue goes, cable P7 should be marked on both the connector block, and quite possibly onto the motherboard. How many pins are on the connector? if its 4 (two rows of two) then this will plug into the motherboard, and is the Intel board supply. If it is either a 20 or 24 pin block, then this will plug into the motherboard, and this supplies your entire mainboard components with power. If it is 4 or 5 pinned, has red, yellow, and black wiring, and has two corners cut off at one side, then this is the power supply cable for a hard disk drive or CD/DVD drive.
If it is a 4 or five pins white or black block spade like connector, then this will serve a floppy, flop drive for power. If it as spade type connector with loads of pins on it, and about the same size as the hard drive and CD/DVD drive power cable as above described, then this is a SATA power cable, and will power any SATA devices. You will also notice that a SATA drive will also have a smaller complete red or black cable that is similar to its bigger SATA power supply cable. The smaller one is for data.
NOTE:
all of these power cables have grooves, notches or angles cut on either one side, or are shaped so that they will only fit one way. Do not try to force these into any other slot, or you may cause damage.
I hope that this is the fixya for you, and if in the meantime you have any further queries or comments, please do not hesitate to get in contact with me.
Your sincerely
Oz
E-Machines... | Answered on Sep 20, 2017
The beep signifies an error. But different bioses have different beeps. You can check with the emachine site to tell you what 1 beep on the machine signifies and you can be guided accordingly. Could be bad power supply, connection, peripheral, etc
E-Machines... | Answered on Sep 01, 2017
You will have to contact cox for that information. I do not know where you are so I do not know the number. Cox can change your password or reset it for you. Been there, had the same problem myself one time.
Did my answer solve your problem?
Rate this as a Fixya if it is fixed.
E-Machines... | Answered on Aug 23, 2017
Bogus unit - return it for another.
E-Machines... | Answered on Aug 21, 2017
For a number to call and get tech support for an emachine you have to purchase it. The best thing I would reccomend is free chat with tech support. If you cannot get any answers from there I would be more than happy to help you out free of charge..
E-Machines... | Answered on Aug 03, 2017
E-Machines eMachines Desktop PC Logo
5,282 questions posted
Top E-Machines Computers & Internet Experts
Steve Allison
Steve Allison
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • E-Machines Computers & Internet
Most Popular Question
r naol comes up says welcome
  • Computers & Internet
