20 Most Recent
HP LaserJet P4015 Printer Questions & Answers
77D4 953864 PRINTER ERROR
This is a communication error. Make sure there isn't anything in the print que. If there is try deleting it. Unhook the printer from the network or computer and try and powercycle the printer. If that doesn't work try a cold reset. Turn the printer on and once the memory starts to count up press and hold the check button until the three lights light up and release then scroll down and hit the check mark on cold reset and see if the printer comes to ready. This will reset the IP address if the printer has one
Hp 4015 printing line down leftside of paper
Most Lines down the page will be caused by the following:1: The Drum of the all-in-one toner cartridge has a scratch on it. Solution: Replace the cartridge.2: The transfer roller is dirty. If you do not have a toner towel, use an unused coffee filter and lightly rub the transfer roller clean. DO NOT USE ANY LIQUID OF ANY KIND ON THE TRANSFER ROLLER!!!If the line remains, consider replacing the transfer roller.3: The Laser window has dirt on it and is blocking the laser from striking the drum at that spot. Clean the laser window with a clean unused coffee filter.
Squealing noise when printing
the gears might be faulty on the printer, but also the fuser can be faulty. get an onsite technician to have a look at the printer
