20 Most Recent Microsoft Windows Vista Home Premium with Service Pack 1: Windows Questions & Answers
Try reboting your computer, if tha does not work, Go to Microsoft.com and contact customer service and tell them about your problem. Also, you can try to download Service Pack 2 or 3.
Before you do this, you may want to try to go to the Control Panel and click on the System and Security option and click on "Find and Fix Problems" and follow instructions, or click on the System and security and check the :Action Center" or "Windows Update."
Explore this page, you will probably find a solution for your problem. You can also try to "restore your computer" to an ealier time. The one you will find under the "Action Center.
I hope that this info will help you to resolve your problem.
Microsoft... | Answered on Sep 24, 2019
i used Nidesoft total video converter
it's support all popular video format
Microsoft... | Answered on Sep 17, 2019
Your Windows Media Player couldn't play DVD format because maybe you forgot to select such file type for which you want WMP to be the default player. To troubleshoot this problem please see the following steps:
  • Step 1: Open your Windows Media Player
  • Step 2: Right click the bottom portion of the player and select TOOLS then OPTIONS
  • Step 3: Go to File Types menu and and check DVD video then click APPLY
Microsoft... | Answered on Jul 11, 2019
how long have you been using the burner? does it burn data and audio completely? try cleaning the lens with lens cleaner and check the CD/DVD you are using to burn your movies. also try using another burning program
Microsoft... | Answered on Jun 29, 2019
.ISO files are archived filed ready for burning to a CD or DVD discs using burning programs like Nero. Thus, Nero software can open and burn this .iso files to discs. Also, Winrar can open and extract the files in a .iso file archive. Download Nero to burn or Winrar to open them
Microsoft... | Answered on Mar 18, 2019
Did you go into the bios to make sure the computer boots from the dvd drive and not the hard drive. Booting from dvd should install vista dvd files.
Microsoft... | Answered on Mar 10, 2019
Microsoft, Windows, Vista Home Premium, blank desktop, mesh, Ideal, personal computer ... Disabled all non ms-services and all startups via msconfig; ..... RunOnce: [*Restore] C:\Windows\system32\rstrui.exe /RUNONCE .... says "Windows Resource Protection could not perform the requested operation." ...
www.experts-exchange.com/.../Microsoft.../Windows/Windows_Vista/Q_23053429.html
Microsoft... | Answered on Feb 07, 2019
Check for any virus/worm and try to do a system restore.
Microsoft... | Answered on Nov 18, 2018
Not Only Skype , Team-viewer is also using port 80 .
To know who uses port 80 go to command promt and type
" netstat -aon " in command prompt and and PID of app listening at port 80 and find athe app on Task Manager -> Servies and Stop it , Then try to Run Papche
If it is not solved
Try by editing httpd.conf of apache (can be found at c:/xampp/apache/conf/ )
If not solved Please attach the error log in order to troubleshoot it .
(log path c:/xampp/apache/log/error.log )
Microsoft... | Answered on Oct 24, 2018
All you need to call is 1-800-Microsoft (642-7676). You will first speak with a Customer Service Agent, you will be redirected to the right department for your issue. Miscrosoft has set-up team, activation, dept for virus issues and even sales. This is the link for the entire Microsoft contact support http://support.microsoft.com/contactus/cu_sc_selector_telephone. Please be reminded that Support for Windows Vista without any service packs installed ended on April 13, 2010. To continue receiving security updates for Windows, make sure you're running Windows Vista with Service Pack 2 (SP2). For more information, refer to this Microsoft web page: Support is ending for some versions of Windows (http://windows.microsoft.com/en-us/windows/help/end-support-windows-xp-sp2-windows-vista-without-service-packs) loadTOCNode(2, 'notice');
Microsoft... | Answered on Sep 29, 2018
problem during copy mp4 file to mobile memory media through data cable error 0x80070057 the parameter is incorrect
Microsoft... | Answered on Aug 08, 2018
Disable pop ups in browser settings. LIke IE > Tools > Pop-up Blocker > Turn on Pop-up Blocker. Or Chrome, or Firefox.
Microsoft... | Answered on Jul 10, 2018
Its is very hard to setup low-light for video chatting if you donĀ“t have a webcam that have a good sensor, i would personal get the logitech c920 hd pro, i own one and its good for low-light.
Microsoft... | Answered on Feb 10, 2018
Right click on file and click troubleshoot compatibility and try and run under vista
Microsoft... | Answered on Feb 09, 2018
hi this is selena am expert to help you to fix this issue for you,kindly call me on +1(518)348-9393 and we will be glad to help you.
Microsoft... | Answered on Oct 04, 2017
hi there,
update your vista to microsoft it can help a lot like SP2 and SP3 updates. Direct X, and others, and also it will smooth your PC operations. but some update need to specify if it is a 32 bit or 64 bit OS.
God Bless
Microsoft... | Answered on Apr 17, 2017
It sounds like you have connection issues.
For starter please consider disabling your firewall (under control panel) then try connecting.
If this doesn't work please try reseting internet explorer settings (under explorer-tools).
Check with tech support of linkedln to see if they require special internet explorer security settings and have them walk you through your settings to make sure nothing has changed.
Last but not least I'd try to go to system restore and restore to a point where you are sure evrything had worked like couple of weeks ago or even one month ago if possible.
(start-programs-accessories-system tools-system restore).
The system restore tool doesn't erase or change any data although if installed any program since that point you are going to have to reinstall it since system restore will restore all registry information to that specific point and disregard everything you did afterwards, therefor I'm going to have to tell you to use at your own risk.
Good luck.
Thank you for using agadycom.
Microsoft... | Answered on Jan 12, 2017
Did this come with your computer or did you purchase it from somewhere? This doesn't install Win 7, just the drivers after the upgrade. If you purchased this cd, the drivers are only good for a Medion computer.
Microsoft... | Answered on Nov 14, 2016
Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
1,762 questions posted
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
VISTA Microsoft
  • VISTA Microsoft
Most Popular Question
webcam optimized low light video
  • Computers & Internet
