20 Most Recent
Dell Latitude E6400 Notebook Questions & Answers
How do you do Print
Press Alt+Fn+(Prnt Scrn) to take screenshot of the active application. To take the snapshot of the whole screen, press Fn+(Prnt Scrn).
Please give good ratings if this answer helped you.
Thanks
Wireless connection Dell Latitude E6400
Look for a switch that turns on the wireless device. Also check in the connection manager if the device is active and the wireless adapter is within range.
How do I disable the internal microphone on a Dell e6400?
Hi Jamiescoffee,
You may want to follow the below steps to disable Microphone:
(1)Right click on the speaker icon in the status bar.
(2)Select Recording device.
(3)Right click on Microphone array and disable it.
However, if you want to enable this later on you may just right click on the same screen and select show disabled device. Right click on the device and enable it.
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
List each function key
o F2 boot to BIOS.
o F12 boot device menu.
0 Fn+F1 sleep/hibernate per power management setting.
o Fn+F2 battery charger ON/OFF.
o Fn+F3 DCP Power Manager Battery Status.
o Fn+F4 numlock ON/OFF for embedded Fn+numeric keypad.
o Fn_F5 scroll lock ON/OFF.
o Fn+F7 DCP.
o Fn+F8 display device.
o Fn+D display OFF/ON (conserve battery without shutting down entire system).
o Fn+Z reset fan temperature table and sensor.
o Fn+Right-Arrow keyboard illumination OFF/ON Auto ALS (lit upon input in dim lighting)/ON (lit upon input). Use DCP to set input device, brightness, and auto OFF delay.
o Fn+Left-Arrow display Ambient Light Sensor OFF/ON (brightness varies with ambient lighting).
o Fn+Up/Dn-Arrows override display brightness until boot to BIOS setting and/or power mananagement setting.
o Alt+Fn+F11 screen shot.
My os is vista how can connect to my jvc flat tv as a second monitor?
How you connect to your tv is not so much a matter of OS as it is dependent on what type of video connections are available on your laptop whether RGB, S-Video, mini-display port to DVI, or HDMI.
Once the tv is connected then you will need to right click your desktop and choose whether you want the tv to be a clone display (desktop to show on both your laptop screen and the tv, or use the extended desktop setting to have half the screen be on the laptop and the other half to be on flat screen tv.
