20 Most Recent Dell Inspiron 6000 Notebook Questions & Answers
You might need to go into the computer's BIOS and see if it's set to boot from a bootable CD or USB device. If it's set to only boot from the hard drive, it won't even look at other drives. Different computers use different ways to access the BIOS: you might try pressing the F12 key when the boot logo appears. Check your owner's documentation - it should tell you the procedure for your computer.
Dell Inspiron... | Answered on Aug 19, 2019
Most dell machines do no come with dvd rewriting as standard. They only come with cd rewriting capability. Unless you specifically requested it as an add on to the spec it probably just has the ability to pay dvd's.
Most internet cafe's will have a machine with a dvd rewriter if you really need to copy a dvd
Val
Dell Inspiron... | Answered on Jun 26, 2019
Sounds like your motherboard battery needs replacing. It is normally a CR2032 button battery and is very easy to change.. It holds CMOS settings when power is turned off.
dell inspiron 6000 change motherboard battery Google Search
Dell Inspiron... | Answered on Jan 02, 2018
Inspiron 6000 Service Manual - Product Support ' Dell US
www.dell.com/support/home/us/en/19/.../inspiron-6000/manuals
DellManuals & documentation for your Inspiron 6000. Last Revised: 7/8/2013. Manuals.Inspiron 6000 Owner's Manual PDF (1724 KB). More Languages. Deutsch ...
DELL 6000 OWNER'S MANUAL Pdf Download. - ManualsLib
www.manualslib.com > Brands > Dell Manuals > Laptop > 6000
View and Download Dell 6000 owner's manual online. ... Dell owner's manual notebook pc inspiron 6400, e1505 (186 pages) ... NOTE: Corporate, government, and education customers can also use the customized Dell Premier Support ...
Dell Inspiron... | Answered on Nov 02, 2017
Better to call Dell technical support for this issue. They're the only one that can provide on your issue. Thank you.
Dell Inspiron... | Answered on Feb 01, 2017
What do you want to know?
Dell Inspiron... | Answered on Jul 02, 2016
Is it plugged in? If so then most likely it is not taking a charge. This could mean your charger has gone bad, the cord leading to it is bad, the cord going to the computer is bad (search for breaks or chewing if you have animals) or the port where you plug it into the computer has suffered damage. This last one is internal as the actual port has come loose where it is attached/ soldered onto the motherboard. You would have to bring it to a qualified repair technician for this. You can also find some online.
Dell Inspiron... | Answered on Mar 06, 2016
Yes, i have a Dell Inspiron 6000 with 2GB in RAM and it´s OK. Better than Vista :-)
Windows 7.1.7600 build 16385 RTM Home Premium
Dell Inspiron... | Answered on Jan 26, 2016
The password cannot be bypassed.
Dell Inspiron... | Answered on Nov 02, 2015
The battery charger is defective.
i think you need to re-install your Operating System again since you got a new HDD wich is tottaly empty i assume so try to install your OS on the new HDD
let me know if it helped
greetings
Dell Inspiron... | Answered on Jun 12, 2015
might be telling you to get a new one.it may not be holding its charge.
Dell Inspiron... | Answered on Apr 06, 2015
There are lots of problems of using wireless LANs in metal buildings, especially if you are trying to go outside the building and into another building. What I have had to do where I work is put an external antenna on the wireless router and use that to transmit the signal beyond the metal shell of the building.
If that still does not yeild satisfactory results, you can set up another wireless router in the "home" location with an external antenna to act as a recieving point for the other router in the office ... essentially this is setting up a site to site network. With both routers working together you should resolve the wireless drop out issue.
Bestbuy also sells a Wireless Booster, this works the same way as I explained with using two routers however if you go that route be sure you have the option to either add an antenna or you can place it near a window (glass cuts down on your signal than steel).
If this fails look at replacing the wireless card; this setup will still provide benefical even if you need to replace the card as it will provide stronger signals in stormy weather as well.
Dell Inspiron... | Answered on Mar 29, 2015
right mouse click on the desktop now show the desktop icons? was this ok?
Dell Inspiron... | Answered on Mar 26, 2015
If you would like to remove AntiVirus 7, click Start -> Control Panel -> Add and Remove Programs. Scroll to the program you would like to remove and click remove.
If you still have issues please let me know if it is Norton AntiVirus 7 or another program. And I can help you further.
Thanks
Dell Inspiron... | Answered on Mar 13, 2015
Hi Valeria Rossi,
Let me know what exactly are you trying to do or when is the proxy being prompted. Depending upon your answer I can check and help you further.
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
Dell Inspiron... | Answered on Mar 12, 2015
You can get a recovery disk from Dell. Go to the Dell WEB site to order one.
www.dell.com
Dell Inspiron... | Answered on Mar 02, 2015
If you cannot get it repaired, note that it has a 120GB disk-drive -- very small when compared to the latest model (500GB), and note that the disk-drive probably is approaching 10 years old -- doomed to "fail" soon. Replace it, and add an external-SATA "Expander" to add another 1000GB of storage of recordings.
Dell Inspiron 6000 Notebook Logo
1,429 questions posted
Ekse
Clive
Clive
View Most Popular
Inspiron Dell
  • Inspiron Dell
Most Popular Question
dell inspiron 6000 wireless driver
  • Computers & Internet
