20 Most Recent
Dell Inspiron 1545 Notebook Questions & Answers
How do I turn off the internal mouse pad?
There is no button/ key to turn off Internal Mouse (Touchpad) in a Dell Inspiron 1545 so you may try following the below steps which might help:
(1)Click start.
(2)Type device in the search box and select device manager.
(3)Double click on Mice and other pointing devices.
(4)Right click on the Internal mouse and select disable.
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
My DVD player on my
are you trying to open dvd files? if yes
try other known good dvd if it opens. if not try cleaning you dvd drive with a cleaner.
are you trying to open dvd movies?
if yes, have you tried playing dvd in your laptop before in case you haven't tried it yet you need a dvd player program try downloading cyberlink powerdvd.
if you have tried it before but not its not working now.
check what are the programs that you have installed lately
maybe it has a conflict with the dvd player software that you are using
try opening the program manually in start menu
manually open the dvd movie.
Dvd DOES NOT PLAY MOVIES AND UNABLE TO LOAD GAME
The standard version has Windows Vista® Home Basic Edition SP1. This version do not have native support for decoder to watch DVD movies. Install a good DVD player like WinDVD or any other DVD player software. This will install the necessary decoder. Once this is done even if the installed trial version expire, your windows media player will still play the movies. However, if you like the software, make it fully licensed version on-line. Hope this helps.
Error code: 2000-0333
hello
error code 2000-0333.
Possible cause Graphic Card Test Failed, Mother Failed, if your Notebook is under Warranty it is better to bring it to Service Warranty Center. or you can repair it by checking the mother board or video card. This problem occurred when your graphic or mother board is failed to start or initiate during start up.
thanks
pls rate
I have a Dell Inspiron
The problem is either the Hard drive has failed and needs replacement or the hard drive is operational but it lost the OS. (Operating System). If the OS is gone, you need to re-install it again..
Error code 2000-0511
seen where? jessica
what PC, what Operating system
why hyjack 2014 year post, why not post your
PC your OS and your symptoms, and not just a number.
here first google hit, ever like google first.?
says fan is not blowing
so clean the fan and vents, all PC pack full of lent never services ever, all do. clean it out.
using blown AIR. (shop air or can-o-air sold at walfart)
I cannot remember my bios password for inspiron
Dell Inspiron BIOS Password Recovery
Each Dell Inspiron has a master password which will clear the BIOS
password. You can get this number by calling Dell Technical Support at
(800)624-9896.
Dell Technical Support will request the Service Tag and Express
Service Code from the bottom of your Inspiron.
If you were not the original owner of the Inspiron, Dell will transfer
registration of the used Inspiron from the original owner with only
the Service Tag and Express Service Code from the tag on the laptop.
To transfer the registration of a used Dell Inspiron, fill out the
Transfer of Ownership form on Dell's web site.
Hope it would help..
My dell inspiron 5423 won't shut down
your guy's answers suck... i have a clean install inspiron 6400 that does the same thing with win 7 or 10, but the whole net seems to be making shiz up to try and give an answer to something they arent even familiar with, sucks sorting thru this shiz havent found a cause yet, only a million know it alls
