You need to find out what that particular error code means and address that particular issue. It could be something very simple but frustrating, just the same..
The dryer is in need of service if a code beginning with an "F" appears in the display.
Alternating between F# and E#, the dryer control has detected a problem that requires service.
Call for service.
erro 103 could cos by head voltage erro or head fit erro. this could be a problem with the printhead lift or transfer roller headfit. reset the printer and try again ...
You don't say the model number. This makes it harder to diagnose. However assuming it is a K-Deck model (try searching around the web with your model number to see if it does match up with a K-Deck). Then F04 means the mechanism is locking up whilst trying to unload. In which case it's all to do with the Load Motor timing. This only applies to K-Deck models though. F04 on another model could be very different.
After 2 more sears repairmen. They replaced, motor control unit. Wrong.. Then the computer control board.. Correct.. Did not wait for the Repairman because they may break something else. Only took 1 month to figure this out.. Sears = Bad
washing machin pipes were frozen in garage, defrosted now. done one wash half way through, error f04 came up. water still in machine and it makes a noise when trying to spin. The fillter knob has broken and i can't undo it to clean it out.
