20 Most Recent Bosch Axxis WFL 2060 Front Load Washer Questions & Answers
My book says for the Axxis WFL 2050/WFL 2060 : from the left while looking at it from the front: detergent for wash, stain remover, middle: fabric softener, fabric conditioner, right one: detergent for soaking agent. (Do not use chlorice bleach in this wasking machine).
Bosch Axxis WFL... | Answered on Oct 01, 2019
The belt that turns the drum has broken.
Bosch Axxis WFL... | Answered on Mar 11, 2018
Bosch WFF washing machine error codes:
E1
- The door is not closed and cannot therefore lock.
E2 - Washer will not fill with water.
E3 - Washing machine not heating.
E4 - Washing machine won't empty.
E5 - Fault in the motor drive circuit.
E6 - Unexpected heating.
E7 - NTC thermistor open or short circuit.
Please note that the codes for the WFF range of Bosch machines differs from other ranges.
Bosch Axxis WFL... | Answered on Feb 03, 2018
There are 4 screws in the door that hold a plastic hinge cover on
.The door will then set into the hinge just fine (PLENTY OF ROOM) and then you put the hinge cover back on and screw the screws in to hold the door onto the hinge.You will likely need a 2nd set of hands to keep from breaking the door.
Bosch Axxis WFL... | Answered on Oct 10, 2017
Follow this link: https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Washing-Machine/39-129-562724-/Bosch-Washer-is-making-loud-noise-WFK2401
Bosch Axxis WFL... | Answered on Sep 22, 2017
Sounds like a bad shutoff solenoid. It operates the valve to let water in and then shut it off. There should be a valve behind the machine where the hose connects to the wall so you don't have to isolate hot water to the entire house.
Bosch Axxis WFL... | Answered on Sep 18, 2017
Sounds like you cannot activate youre imagination maybe Ill do this for you one time here goes ~: You or someone left coins in your pockets jeans cardigan whatever they got out of garment while in the wash spin and worked themselves into the machine and now its bug-gerred innit?
Bosch Axxis WFL... | Answered on Aug 05, 2017
hi .it might be likely that the coin is stuck in the pump .to access this you need to open the panel at the front and open it panel.see pic.please note that some water will come out when you open it.put a big towel in front.of it..
Bosch Axxis WFL... | Answered on Jun 12, 2017
My Bosch washer turns "on" and water runs but it does not spin or complete wash. I hear the machine "clicking" as if it is attempting to to function but no spin or full wash cycle.
Bosch Axxis WFL... | Answered on Mar 15, 2017
Bosch Axxis WFL 2060 Front Load Washer Logo
675 questions posted
Top Bosch Washing Machines Experts
Marvin
Marvin
jimorris77
Dw Wooten
Dw Wooten
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Bosch Washing Machines
Most Popular Question
door hinge broke bosch axxis front
  • Washing Machines
