20 Most Recent Bosch Exxcel WFX 3267 Front Load Washer Questions & Answers
If the machine has been moved recently, ensure that it is level and not leaning forward. Pull the dispenser completely out (pull as far as it will go, then press down on the blue section in the fab cond compartment to fully remove) make sure it is clean and free or fab cond and powder build up. Following the diagram, check that part 0412 is clear (this can be done when the drawer is out by putting some water in the dispenser manually and seeing if it flows quickly. A baby bottle brush can be used to clear it, if it is blocked.769ae95c-736a-45f2-a40f-6dd121e32863.png
Bosch Exxcel WFX... | Answered on May 04, 2013
If the motor is not spinning, you may have a burnt out motor or faulty Motor Control Board. Else, if the motor is spinning, fix the belt from the motor to the drum.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Bosch Exxcel WFX... | Answered on Oct 30, 2011
(no promises but it's worth trying this!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Bosch Exxcel WFX... | Answered on Jun 16, 2011
Hi,There are quite a few solutions available here:http://www.fixya.com/tags/error_f04/page-5
Regards,Icom1
Bosch Exxcel WFX... | Answered on Apr 03, 2011
This sounds like a bad main control board. Try unplugging it for 10 minutes then replug an try again. If you get the same results replace the main controller.
Bosch Exxcel WFX... | Answered on Jun 16, 2010
https://washingcodes.com/bosch-dishwasher-error-codes/
Try the above. They are listed as knowing your brand codes.
Bosch Washing... | Answered on Apr 16, 2019
What is a Bosch Max 800??
Bosch Washing... | Answered on Apr 14, 2019
Bosch Exxcel WFX 3267 Front Load Washer Logo
18 questions posted
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Bosch Washing Machines
Most Popular Question
leak detergent drawer
  • Washing Machines
