20 Most Recent Bosch WFMC 3200 Front Load Washer Questions & Answers
Not many machines are belt driven these days, but the symptoms are those of a slipping belt, or friction against a failed rubber mount.
To find out more you will need to remove the case (or enough of it to see what happens while it is working.
Be on the lookout for some rubbery thing (either a part, or something from a previous load) jammed somewhere where the rotating drum scrapes it.
A burning rubber smell is different to a burning motor windings or transformer smell but maybe only to afficionados. Could be a winding failure on the motor too.
Unplug, un-case and plunge your schnozz into the works seeking the odiferous source. Sounds like I am kidding, but I am not - really try it. You may need to dry run it for a while to elicit the smell before unplugging etc.
Please post how you go, and what it eventually turns out to be.
Bosch WFMC 3200... | Answered on Feb 03, 2018
This is several issues rolled into one. The clank noise is concerning and the smell could be the heating element for high wash temps. The other thing is the control module could be causing a lot of this. The water valves could be causing the fill issue and the clank could be the pulley on the drum. The bad thing is there are not a lot of parts for that machine as it was 13 years old. The control board is almost 300 dollars. Taking the time to trouble shoot it requires tools and patience . The service manual link is attached. Bosch WFMC3200UC Training Manual
Bosch WFMC 3200... | Answered on Dec 13, 2017
you may have a faulty water solenoid
Bosch WFMC 3200... | Answered on Oct 29, 2017
I think you should concern with the manufacturers of this company because concerning someone might be risky. UK Academic Writers
Bosch WFMC 3200... | Answered on Jul 25, 2017
Hi.
E2 means uneven balance.
The error code gets reset using the following procedure:
Ensure that the machine door is closed. Turn the dial in the OFF position.
Hold down Start/Pause button and turn the dial anti clockwise at the same time until its position is pointing at the Express (15mins) program.
Hold down Start/Pause button until the e2 message starts flashing (or keep holding for about one minute)
Release the button.
Turn the dial again to the OFF position.
The machine is reset. Select any program.
If the message comes back after selecting program, then there is still a balancing problem. Remove and redistribute load, check floor and ensure machine is at level.
Bosch WFMC 3200... | Answered on Jul 29, 2015
Most likely your door seal
Bosch WFMC 3200... | Answered on Jul 12, 2015
he e2 error is a generic error that the machine shows if it's been overloaded or if the load becomes unbalanced during a wash cycle.
To fix you must do a master reset of the washing machine.
1. Close the door and make sure the dial is pointing to the "OFF" function
2. Hold the Start/Pause button and turn the dial anti clockwise (to the left) to the "express 15 min" program at the same time.
3. Hold the Start/Pause button for a minute (the e2 message is meant to start flashing after a minute of holding the button down however with my washing machine this didn't happen) (and neither with mine)
4. Release the button and turn the dial back to the "Off" function.
5. Select any program and the message should not be appearing
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Bosch WFMC 3200... | Answered on Feb 13, 2015
Hi
I can't help much with your drainage problem but you can get a manual by going here:
Bosch Washer Lave linge Operating Care and Installation Instructions Nexxt...
and clicking on the download ( 25344069-jbgilj0tmqv44adxhetcg2bu-4-0.jpg) symbol/ It will ask you where on your hard disk you want to save the manual and it is in pdf format so readable with Adobe Acrobat Reader.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Bosch WFMC 3200... | Answered on Dec 29, 2014
Read the manual. If you don't have a manual, search online for it. Or ask at the store where you purchased the washer.
Bosch WFMC 3200... | Answered on Nov 26, 2014
do you have cold water
check water vavle
Bosch WFMC 3200... | Answered on Aug 19, 2014
I dont.. the service guy does..
Bosch WFMC 3200... | Answered on Aug 01, 2014
Did you check the manual for further instructions? You can find a PDF copy here: Bosch Classixx 5 Manual.
Bosch WFMC 3200... | Answered on Jul 15, 2014
Hey there, welcome to Fixya! The above answers were pretty helpful, did you fix your problem with them? Did you check the manual for further instructions? You can find a PDF copy here: Bosch Classixx 5 Manual
It could be a defective fill valve or the cold water supply could be turned off.
Bosch WFMC 3200... | Answered on Jun 26, 2014
Probably the small filter screen in the cold water supply line is plugged up with sediment. The screen will either be directly on where the hose connects to the supply line, or may be on the rear of the washing machine where the cold water supply line connects to the washer, usually a simple screw-on just like a garden hose.
Bosch WFMC 3200... | Answered on Jun 25, 2014
Bosch WFMC 3200 Front Load Washer Logo
276 questions posted
Top Bosch Washing Machines Experts
Marvin
Marvin
jimorris77
Dw Wooten
Dw Wooten
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Bosch Washing Machines
Most Popular Question
wae28162
  • Washing Machines
