20 Most Recent Bosch Classixx WFL 2066 Front Load Washer Questions & Answers
all lights are flashing on bosch classixx express no thinh working no water intake door is locked what is the problem and can i do it myself
Bosch Classixx... | Answered on Oct 15, 2019
the key symbol is a child lock , look in your manual to see how to turn off this feature
Bosch Classixx... | Answered on Jul 27, 2017
The Solution: Top up the softener tray with extra water so that it is up to the 'max level' mark.
The softener tray works by a siphon action. Thus, the reason the tray does not empty is that not enough water is added by the machine during the softening cycle, so that the machine does not completely fill the softening tray; only when the softening tray is filled beyond the 'max' mark does the siphon action works. A partially filled tray will never empty - it's impossible due to the siphon.
The reason that not enough water is added to the tray during the softening action is that the water inlet of the machine is partial blocked (you can try to fix that) but it is simpler to just added more water to the conditioner tray.
Thus, the easiest way to ensure that the softener tray empties every time (after adding the softener to the softener tray of course) is to top up the softener tray with extra water, top it up to the 'max level' line (keep a bottle of water by the machine). That way, even if only a little water is added to the softener tray during the softening cycle by the machine it is enough to trigger the siphon action and the tray will empty!
Works for me every time, and no need to remove any parts - I used to take the tray out, clean it, scrub the outlet holes that fill the tray etc, but they used to gum up again quite quickly!
Hope that helps
Bosch Classixx... | Answered on Jul 10, 2016
the tool will be a spanner of the right size
The warranty is the receipt of purchase as that gives the date of purchase
Bosch Classixx... | Answered on Jun 21, 2015
You can download the user manual at: http://lesepc.com/uploads/b/bosch-classixx-wfl-2066-manual.pdf
Bosch Classixx... | Answered on Apr 20, 2015
If its showing a key symbol then the child lock is on.Press and hold the start/pause button in for several seconds and this should take the child lock off and start to work again.
Bosch Classixx... | Answered on Mar 10, 2015
Drain filter/catch basin is most likely blocked with food. You should be able to access it by the inside of the dishwasher...check you manual if you have one for components.
Bosch Classixx... | Answered on Mar 01, 2015
Bosch Classixx WFL 2066 Front Load Washer Logo
646 questions posted
Top Bosch Washing Machines Experts
Marvin
Marvin
jimorris77
Dw Wooten
Dw Wooten
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Bosch Washing Machines
Most Popular Question
fault f21 pump cleaned fault reset
  • Washing Machines
