20 Most Recent Hotpoint Aquarius WD640 Front Load Washer/Dryer Questions & Answers
F01 - Short circuit motor triac - Book a washing machine repair. F02 - Motor jammed tacho detached - Book a washing machine repair. F03 - Wash thermistor open/short circuit - Book a washing machine repair. F04 - Pressure switch jammed on empty - Book a washing machine repair. F05 - Pressure switch jammed on full - Book a washing machine repair. F06 - Program selector error - Book a washing machine repair. F07 - Heater relay stuck - Book a washing machine repair.  F08 - Heater relay cannot be activated - Book a washing machine repair.  F09 - Incompatible eeprom - Book a washing machine repair.  F10 - Pressure switch not sensing correctly - Book a washing machine repair.  F11 - Pump cannot be activated - Book a washing machine repair.  F12 - Communication error - Book a washing machine repair.  F13 - Dryer fan or dryer thermisotor faulty - Book a washing machine repair.  F14 - Dryer element faulty - Book a washing machine repair. F15 - Dryer element relay faulty - Book a washing machine repair.  H20 - Not fillings. Check tap, hose and inlet valves LOCKED - Check interlock - Book a washing machine repair.  Here is a list of fault codes. I hope this helps !
Hotpoint... | Answered on Nov 21, 2018
F6 error is apparently a motor fault. The
motor could be jammed, open circuit ,
burnt out. It may just be a broken wire
or connection come off. Check the motor.
Hotpoint... | Answered on Apr 21, 2018
Check all thermostats , check to be sure you have 220 volts coming into the machine. Use ohm meter & check from heater element to the heater case or cabinet to see if the element is grounded. Positive to element & Negative to case should show no ohms if it does it is shorted. Also heater circuit runs through a centrifical switch on the motor
so if the motor quits the heater shuts down so you don't have a fire. When the motor is not running the fan stops.
You could check this switch but it don't happen very often. check this switch last. Hope this will help you
Hotpoint... | Answered on Feb 02, 2018
My list of Indesit (Hotpoint, Ariston) errors does not include an 'F06'!
If you have not done so already try checking that thre is no drainage blockage/stopage.
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Hotpoint... | Answered on Dec 23, 2017
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
All error codes at above link...
Hotpoint... | Answered on Dec 13, 2017
go to the parts website for Hotpoint for price or Google the part number and someone will post it for sale.
Try going to You-Tube for instruction video on replacing.
If it is still under warranty, call mfg or warranty company.
Hotpoint... | Answered on Nov 16, 2017
i can try to help you with this problem. if you pop the cap off the top of the agitator you will see a nut, once you take the nut off you should be able to jiggle the agitator in an upward motion to remove it then retrieve your wire and gently slide agitator back on so as not to ruin the splines if there are any. good luck
Hotpoint... | Answered on Sep 30, 2017
you could have a broken pipe on the filler or the seal has gone on the drum you would need to have a look, either way they are easy to fix or replace. drain pipe can leak if the pipe has come off the pump also check this but you will need to remove the case to get to look, always unplug the washer before touching any screws, remove case and look at the pipes and make sure they are seated in the right place.
Hotpoint... | Answered on Sep 09, 2017
You will need to replace the entire control panel assembly to cure this problem
Hotpoint... | Answered on Jun 29, 2017
Martha, Try running another cycle, for some reason I think machine is sensing it still has water in it. If after running another cycle dose'nt do it, check links below to see (2nd link) how to open door manually with out damaging machine. press the helpful button
How to fix washing machine door lock in Hotpoint washing machine
Opening locked washing machine door
Hotpoint... | Answered on Feb 10, 2016
This just happened to my hotpoint washing machine, I realise it has been a long time since this has been asked but since my answer is different from the others I thought I'd add it anyway in the hope it will be useful to someone one day. The fix was super easy, all that was wrong was the plastic knob itself, which had broken internally. I only found this out after taking the top and front covers off, which is an easy enough procedure, I did it this way: unplugged the washing machine, removed two screws from back of machine that hold top cover in place, then using a putty knife pushed between the top and front covers front to back right at the corners, thus releasing the top cover, once this was out I could unclip the front cover and get to the screws that hold the control board to the front cover. I unplugged the electrical connection to the board, removed all the screws and unclipped it from its plastic cover. At this point I could see the plastic knob had broken, I recovered the broken bit and glued it back on. After the glue dried, I just put everything back in place reverting the previous actions. Hope this helps. If you don't have glue or can't find the broken piece, you should be able to just buy another plastic knob off the internet.
Hotpoint... | Answered on Feb 06, 2016
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
906 questions posted
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Hotpoint Washing Machines
Most Popular Question
washer dryer baby cycle wash although
  • Washing Machines
