The pressure setting on your pressure switch has went out of calibration causing the machine to overfill. If you take the lid off by removing the 2 screws at the rear and sliding it back the pressure switch is underneath on the left. Try unscrewing the larger screw in the middle anti-clockwise 1 full turn i.e. 360 degrees and try a wash. If it still does it the try 1 more turn. If it still happens then you will need to replace the switch. Hope this helps.
