Frigidaire Front Load Washer
Take a brief Survey Take a brief Survey   Add to My Products Add
Problems with Frigidaire Front Load Washer?
Troubleshooting and Support
Solved Problems for Frigidaire Front Load Washer RSS Feed Post a New Problem
front loead washer will not spin/rinse,
the water drains but the clothes are all wet. so it will not spin/rinse
STAFF 1 Solution
Frigidaire Front Load Washing Machine:...
I own a Frigidaire Front Load washer, Model # LTF2140ES3. I have owned it for less than two years now. I have the same...
8 Solutions
Loud thumping while spinning
Loud thumping while in spin cycle like drum is hitting something.....bam bam bam. I tried redistributing the load,...
1 Solution
washer won't final spin
My Frigidaire front loader won't do the final spin & drain. I had a repairman tell me it was the water pump &...
1 Solution
Frigidaire front load washer (LTF600ES1) ...
Can someone please tell me what error E20 means and how to fix it? It comes up within 10 minutes of the wash cycle. I...
14 Solutions
Frigidaire Front load washer mold
I use my front loader at least twice a day and 3 or 4 times on the weekend. I have noticed a black mold all around the...
1 Solution
Very loud noise as drum is spinning
The motor seems to be fine. The noise is a loud clunk as it hits certain points in the spinning cycle....almost like...
1 Solution
Unsolved Support Problems
Unsolved Problems for Frigidaire Front Load Washer RSS Feed Post a New Problem
pauses with error code 13
2yr old frigidaire front load washer won't cycle through to finish. It stops at random places and displays an error 13...
Post a Solution
E20 code
My washer will not turn on It shows E20 in the window I was washing a small blanket and there is water on the bottom...
Post a Solution
frigidaire front load washer drum loose...
from what i have read about the frigidaire front load washers...the bearings and spiders fail which causes the drum to...
Post a Solution
Re-attaching Rubber Seal from Frigidaire...
I replaced the tub assembly on my Frigidaire Gallery Front Load washer because the bearing was shot. I replaced the...
Post a Solution
I have a Frigidaire Front
I have a Frigidaire Front loading washer. I changed the entire tub assemble last night because the bearing was bad. A...
Post a Solution
Fridigaire Gas Dryer spins ,but wont heat
Fridigaire model GLGR341AS1 Serial no.XD23509749 2002 Gas the dryer spins fine but will not heat. the inside...
Post a Solution
FRIGIDAIRE FRONT LOAD WON'T SPIN
I HAVE CHECKED THE ERROR CODES AND HAVE RECEIVED E47 AND E41. I HAVE RAN THE DIAGNOSTIC TEST AND BOTH HAVE RESULTED IN...
Post a Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
Washer TypeWasher
Load TypeFront Load
Volume Capacity3.5 cu/ ft
Wash
Wash Presets7 Wash Presets, including: Permanent Press, Delicates, Hand Wash
Spin Speeds5 Speeds
Washing MethodDrum
Extra SettingsQuick Wash · Extra Rinsing · Heavy Duty
Convenience
Control FeaturesDigital Display · Electronic Touch · End-of-Cycle Signal · Time Remaining Indicator · Delayed Start Timer
Efficiency
Energy EfficiencyEnergy Star Compliant
Other Features
Exterior ColorWhite
Dimensions
Overall Depth27 in.
Overall Height36 in.
Overall Width (Display)27 in.
Frigidaire Contact Information
Main support number1 (800) 374-4432
Sponsored Links
Loading problems.
Top Washing Machine Experts
IFIXALL
35 solutions
TV and Video, Software, Large Appliances...
Ask Me
Wiz
geemarie
25 solutions
Digital Cameras...
Ask Me
Wiz
ngfam1
23 solutions
Cars, Cellular Phones, MP3 and Digital Media Players...
Ask Me
Wiz
Repair Service
Find Washing Machine Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
