20 Most Recent Hotpoint WF430 Front Load Washer Questions & Answers
the best thing you can do is remove the power lead the take the top panel off and push the drum to the rear and using a small screwdriver remove the lock and replace it from the manufactures website (you can switch off the machine at anytime and restart it by turning it back on and pressing start again depending on the type of machine of course) eric
Hotpoint WF430... | Answered on Jan 17, 2018
???? ITS NOT SUPPOSE TO SPIN WHILE WASHING ? DO U MEAN ITS NOT AGITATING? THEN LOOK AT UR PRESSURE SWITCH AND UR CAM DOGS. MOTOR COUPLER OR BELT. NEXT UR CLUTCH BRAKE ASSEMBLY MAY BE BAD
Hotpoint WF430... | Answered on Jun 11, 2015
You dont...
Take of top cover, remove top front panel. Remove front, two screws top front, two screws bottom front, loosen the doorlock and door bellow. Disconnect everything on the drum, (motor, dampers, heater, water pressure switch hose ect. Lift the drum out. Good luck.
Hotpoint WF430... | Answered on Sep 27, 2014
Brusheson motor will be worn. The door lock is in series with the motor so if brushes worn it interrupts the signal telling the board the door is locked. New brushes will likely be all it needs.
Hotpoint WF430... | Answered on Dec 02, 2013
This was answered earlier, please check and remove the control panel to reset the switch
Hotpoint WF430... | Answered on Nov 21, 2013
You need to remove the control panel and get the switch pushed up .
please check this link for tips: control panel
Hotpoint WF430 Front Load Washer This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Hotpoint WF430... | Answered on Aug 05, 2013
you need to call A&E FACTORY SERVICE @ 1-800-862-9226 or go to www.aefactoryservice.com clink here
Hotpoint WF430... | Answered on Jan 03, 2013
The easyest way to fit these belts is to locate it on the motor pulley and as far onto the right hand side of the main pulley (viewed from the front of the machine) as possible. Hold it on the main pulley with a cable tie and rotate the drum anti clockwise by turning it from inside. The belt will be drawn onto the pulley and the cable tie will snap as it rotates. (Easy)
Hotpoint WF430... | Answered on Nov 08, 2012
Hotpoint WF430 Front Load Washer Logo
74 questions posted
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Hotpoint Washing Machines
Most Popular Question
off amp start buttons receeded cannot
  • Washing Machines
