When you said you used the cleaning utility 30 times, it reminded me that cleaning can only be done a few tims before ink is depleted.
When you said that you changed the cartridge and got nothing, it reminded me that one should remove the clear tape on the cartridge before installing the new cartridge, or else no print out will be seen.
If a new cartridge is installed and it still does not print out magenta, then the printer may require service at canonusa.com:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp610?pageKeyCode=25
I have the same problem. Tried cleaning 7 times. Advice from a very knowlegeable guy at Cartridgeworld is that the print head needs replacing - expensive! The print head has small heating elements which can burn out; successive cleaning overheats the adjacent elements and then they burn too. PREVENTION is so much better, so in future regularly print a nozzle ckeck pattern (use the 'Settings' then the 'Mainenance' buttons) and do a clean only if the printout shows one is needed.
