20 Most Recent Canon PIXMA MP600 all-In-One InkJet Printer Questions & Answers
pull out your ink carg and on your printer and then put back the cag and use your printer its work aone
Canon PIXMA... | Answered 3 days ago
Hi Whitey621
Error code 5100 Try
Solution 1:
Look inside for a tiny object like a piece of paper, a staple...
Solution 2:
There is a thin plastic strip running across the width in front of and below the drive belt: there are fine black vertical lines on this strip. If the strip gets a piece of crud on it, you get an error during the start-up sequence.
Gently clean this strip with a damp lint-free tissue
Hope It Helps: Pineworks.
Canon PIXMA... | Answered on Sep 12, 2019
Kindly remove the printer from add or remove place
and then re install the printer from 0 it will start work and kindly remove the old printers from your computers which are no more available to you.
Canon PIXMA... | Answered on Aug 22, 2019
Could be a cable issue or wireless modem
Canon PIXMA... | Answered on Jul 19, 2019
According to the quick setup manual, this printer supports only bluetooth. In other words it is not a wifi printer. In order for you to be able to print on it with a wifi device like a tablet, you will need first to connect your printer with a usb cable to a computer that is connected to your wireless network and then you will need to share the printer on the local network. During the installation process to the connected computer, you should be asked wether you want to share it or not with the network. Simply answer "yes"
Canon PIXMA... | Answered on Jun 11, 2019
6000 is a paper jam or jammed sensor.
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp600#ServiceAndSupport
Click service and support, then enter error 6000, then click Error LCD ... 6000..., then click Removing paper jams mp600. Sorry, but they use javascript so I can't give you a more direct link.
Canon PIXMA... | Answered on Nov 06, 2018
The manufacturers removed the option long time ago due to the printheads and muzzles which get screwed up while printing with one or more empty cartridges. here are some explanations and tutorials on how to actually print with an empty cartridge:
How to print without black ink
Canon PIXMA... | Answered on Sep 05, 2018
Just the driver you need to integrate with your system.
Canon PIXMA... | Answered on Aug 29, 2018
Solution available on this fixya topic:
/support/t1579890-ink_cartridge_being_rejected
Canon PIXMA... | Answered on Aug 14, 2018
1. Press ON/OFF switch to reset the multifunction device 2. Removing paper jams MP450 / MP460 3. The MP460 may require repair
heres the problems currently with mp460 and at bottom is the link
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=13369
this is the solutions for the mp460
for the guest
clean out your ink absorber after unplug
reset printer you still have a little credit card sized paper in your printer that you need to remove it
Canon PIXMA... | Answered on Aug 10, 2018
I just had the same problem, tried everything and resigned myself to buying a new one. I was about to throw the thing when I saw the Card backing of an A4 Pad. I thought I have nothing to lose so forced this through the machine and Bingo. It cured it.
Canon PIXMA... | Answered on May 15, 2018
Hi, Be sure to check the printer settings to make sure the wifi option is selected on the printer itself. Once wifi is turned on reboot your computer. It should find it then. Check back if that doesn't solve it and together we can continue the troubleshooting.
Canon PIXMA... | Answered on Jan 23, 2018
Hi Peter.
  1. Turn off the machine and unplug the power cord from power supply
  2. Plug the machine back in and turn the power on
    NOTE- If you disconnect the power plug, all the faxes stored in the machine's memory will be deleted
If the error message is still showing, then it is necessary to deliver or send the printer to an authorised repair centre. I am assuming it has run out of warranty, so any repairs will cost you.
You can find the details of your nearest repair centre using this link interactive repair centre locator.
Also It may be worth checking the roller bar and rollers to ensure they are running at the same speed when flipping the paper over.
Regards
David
Canon PIXMA... | Answered on Dec 03, 2017
Canon PIXMA MP600 all-In-One InkJet Printer Logo
1,452 questions posted
Clive
Clive
old marine
old marine
Ekse
View Most Popular
PIXMA Canon
  • PIXMA Canon
Most Popular Question
connect canon mp600 wifi
  • Office Equipment & Supplies
