20 Most Recent Canon PIXMA iP4300 InkJet Photo Printer Questions & Answers
All you need is just to turn the paper upside down. This printer requires the paper with the glossy face down.
Canon PIXMA ... | Answered on Jan 05, 2018
Hi you mentioned that the Ink is new and that you have cleaned the ink heads, have you checked if the silicon Film for the ink cartridge contact was removed?
if that film is not removed cleaning the printer head will still not detect the ink cartridge for the Black on your printer.
Turn your printer OFF and remove all your print cartridges then install all of them again one at a time then turn the printer back ON, see if all the ink cartridges are now detected and if the Black will now print.
Also if you can
Canon PIXMA ... | Answered on Nov 17, 2017
possible defective cartridges, car printing
Canon PIXMA ... | Answered on Nov 04, 2017
Take the print head out of the machine and sit it in a saucer of very hot ( just off boil) water about 10mm deep for a minute. Take it out and sit in on a pad of paper towel to dry briefly before returning it and the cartridges into the machine. Give it a deep clean and try again. If still no good, the print head has probably had it.
Canon PIXMA ... | Answered on Nov 02, 2017
Press and hold the stop button on the printer for 10 seconds and see if this clears
Canon PIXMA ... | Answered on May 03, 2017
Hello, first unplug the the printer and take out the cartridges, first dab them on a wet paper towel until the ink start flowing, then take a q-tip dipped in alcohol and where u insert the cartridges, clean the print heads, replace the cartridges and power up. If that doesn't help it you have bad cartridges.
Canon PIXMA ... | Answered on Nov 29, 2015
Ink jets may be clogged, go into your printer software for the canon. At someplace in there there should be an option to run the cleaning program on the printer. This is used to clean out the jets and clean up the printer a little bit. Make sure that you have lots of ink, Cleaning process uses a lot ink
Canon PIXMA ... | Answered on May 15, 2015
There is many reasons for that,
are you printing any thing???
Just restart the printed and see if lights turned off....
Canon PIXMA ... | Answered on Apr 05, 2015
you can get letest drivers from cannon's official website
Canon PIXMA ... | Answered on Mar 28, 2015
Hello friend, I had downloaded a Good canon iP4300 service manual from below link:
Canon iP 4300 service manual:
http://goo.gl/45JFrF
Good luck on repairs.
Canon PIXMA ... | Answered on Dec 02, 2014
Hello friend, here is a link for Canon ip4300 service manual, is a good manual.
Canon ip4300 service manual:
http://goo.gl/WQTZJl
Thanks
Canon PIXMA ... | Answered on Nov 27, 2014
One, or more, of your ink tanks are empty. Open the Canon IJ Status Monitor on your computer to check the ink level information. Replace the appropriate tank.
Canon PIXMA ... | Answered on Nov 07, 2014
Yvonne, the printer has no timer on it on. Check your driver settings on your computer. Specifically, check your advanced tab in your driver and see that "Always available" is clicked on.
Canon PIXMA  iP4300 InkJet Photo Printer Logo
528 questions posted
Clive
Clive
old marine
old marine
Ekse
View Most Popular
PIXMA Canon
  • PIXMA Canon
Most Popular Question
need service manual canon ip4300
  • Office Equipment & Supplies
