20 Most Recent
Canon MP140 PHOTO AIO All-In-One InkJet Printer Questions & Answers
Canon pixima mp140 error code E4
following error codes i found
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
Help with error 1401
To print without color ink go to START>control panel>PRINTERS & OTHER HARDWARES>PRINTERS & FAXES>Right click to your printer>PROPERTIES>MAINTAINANCE>INK CARTRIDGE SETTING>then select BLACK ONLY.
I think it fix your problem.
Can canon pixma mp140 scan without ink
Well, here I am, nine years later, having the same problem. I have a Canon Pixma MP180 and want to use it only as scanner, with no cartridges at all. The method described does not do the trick for my Canon. So, could you help me?
Error 5
Windows Vista or Windows 7 users may experience a Printer Error 5 when attempting to print from your MYOB software.
To overcome this issue, turn OFF the User Account Control (UAC) in Windows. See below for instructions.
Note: Our support note Printer error messages, definitions, and solutions can be used if you are not using Windows Vista or Windows 7 and are receiving a Printer Error #5.
To turn off UAC in Windows Vista
-Close out of your software.
-Click the Windows Start button and choose Control Panel.
-In Windows Vista click User Accounts and Family Safety.
-Click User Accounts. You may need to select a User Account, if so, choose any account.
-Click Turn User Account Control on or off.
-You will be prompted with a window entitled Windows needs your permission to continue. Click Continue to this message. If you are not setup as an Administrator user on this machine, you may be prompted to enter a Administrator Username and password.
-Deselect the option Use User Account Control (UAC) to help protect your computer then click OK.
-You will be prompted to restart your computer. Click Restart Now.
-You may get a warning to Check your computer security. This is a standard message that Windows recommends User Account Control to be always turned on.
To turn off UAC in Windows 7
-Click Change User Account Control settings.
-Click and drag the slider to the lowest position, in other words Never notify.
-Click OK.
-Restart your computer to complete this change.
Canon PIXMA MP140 error code E 2
error E 2 =>
The machine is out of paper. / Paper does not feed.
Reload paper in the Auto Sheet Feeder and press the Black or Color button.
I placed a re-filled ink cartridges in my canon mp140 printer and
Computer chips in cartridges must be reset before the printer will recognize them as full. If you paid a shop to refill your cartridges take them back and complain. The best places will test the refilled cartridge before giving it to you.
Please note durability of prints using cheap ink is usually very poor, and as a result the manufacturers ink is usually much the better choice.
