20 Most Recent Canon PIXMA MP530 All-In-One InkJet Printer Questions & Answers
Canon printer is one of the best brands in the world many big organisation are relying on the canon printer, its unmatched printing quality and versatility makes it more best printing devices in the world, but every machinery devices causes problem, but don't worry we have a proper solution, Kindly visit us to get the proper solution
How We Support:
100% Fully Assistance
We Are Available 24*7
We Work Fast as per Customer demand
For More Info Do Visit Us: canon printers error code 5100
Toll-Free No: +1-888-633-7151
Canon PIXMA ... | Answered on Sep 12, 2019
Please remove all cartridges. Using a moist cloth clean the golden contacts on cartridge as well as printer. DO NOT touch nozzle of cartridge. Dont insert the cartridge yet.
Please do this :
1. Remove the power cable from printer. Remove the USB cable that connects printer to computer (remove it from printer as well as computer's usb port)
2. Press the printer power button and keep pressed for 3 minutes then release
3. Now plug in the power cable and usb cable (connect printer to computer) and power on the printer.
Now insert cartridges and see if error goes away.
Do not forget to rate my answer.
Canon PIXMA ... | Answered on Jun 10, 2019
If you're throwing it away, take a hammer to it. Once it's been fairly well destroyed, you should be able to find the memory card, and trash it. If not, trash all the internal boards. This has the added benefit of letting you work off a little everyday annoyance.
That's the simplest way, and the way the DOE/DOD does it, as well as many corporations....except they use an industrial shredder.
Canon PIXMA ... | Answered on Mar 25, 2019
The "inner cover" can be seen if you open the paper output door, which you have to do to open the "printer cover" to get inside the machine and install the ink cartridges. The inner cover is a black bar right inside here. Push it up firmly enough , and it will snap up.
Regards,
Sai.
Canon PIXMA ... | Answered on Nov 05, 2018
Hi. That happens sometimes with generic cartridge. It seem that print head is defective.
Canon PIXMA ... | Answered on Feb 19, 2018
PIXMA MP530
Linke to manuals, and free Canon telephone number and email support.
Canon PIXMA ... | Answered on Jan 27, 2018
Receive Mode Settings Select from the following receive mode options to suit your needs. Once you've decided on which receive mode to use, follow the below instructions to set the receive mode using the operation panel. Receive Mode Setting
  1. Press the <FAX> button to enter Fax mode.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
  4. Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
Types of receive mode
Select the receive mode according to your needs.
Receive mode
Purpose
FAX/TEL AUTO SW When you want to receive faxes automatically as well as voice calls. FAX ONLY MODE When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only. DRPD When you have subscribed to a DRPD service with your telephone company. MANUAL MODE When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually. ANS.MACHINE MODE When you want to receive voice messages on your answering machine and receive faxes automatically. FAX/TEL auto switch
FAX :
The machine does not ring but will receive the fax automatically. Voice call :
The phone attached to the machine will ring. Pick up the handset to answer the call. Note:
  • Ring start timing and Telephone ring length can be specified in FAX/TEL auto switch in the Receive mode settings.
  • If you want the telephone to ring when it receives a fax, connect a telephone to your machine and enable the Incoming ring settings in RX settings.
  • The phone attached to the machine may not ring depending on the telephone type you are using.
FAX only
FAX * :
The telephone does not ring. The machine will receive the fax automatically. Voice call :
You will not be able to answer the call. * If you want the telephone to ring, connect the telephone to your machine and enable the Incoming ring settings in RX settings menu.
DRPD
FAX :
Your telephone line will ring according to the ring pattern you have chosen and receive the fax automatically. Voice call :
Your telephone line will ring according to the ring pattern you have chosen. Pick up the handset to answer the call. Note: Specify the FAX pattern in the DRPD: Set FAX ring pat. in RX settings menu.
Manual RX
FAX :
The telephone attached to the machine will ring. Pick up the handset and if you hear a beep tone, press the <Color> or <Black> button on the machine to receive the fax. Voice call :
The telephone attached to the machine will ring. Pick up the handset to answer the call. Note: If you are far from your machine, you can use the remote receiving function to receive faxes. Pick up the handset of the telephone connected to the machine and press 25 (the remote receiving ID).
Ans. machine connect
FAX :
First the answering machine connected to your machine will respond to an incoming call, and then the machine will receive faxes automatically. Voice call :
The answering machine connected to your machine will respond to an incoming call. Note:
  • Set the answering machine to answer on the first or second ring.
  • The entire message should be no longer than 15
Canon PIXMA ... | Answered on Jan 15, 2018
I have the same issue as well - I just open the printer, pop out the cyan cartridge, and reinsert it (the same one). This generally works - sometimes I need to do it once or twice. I figure I'll be patient and keep doing this until I a) finish the cyan ink cartridge, b) replace it out of annoyance, or c) through the printer out the window in total frustration.
Interesting to hear about "faulty" cartridges though - I shell out for the "authentic" Canon cartridges which you would think would be reliable - maybe I should switch to using the imitation ones if I'm going to have issues with them anyway...?
Canon PIXMA ... | Answered on Dec 08, 2017
Check the Lan/Wlan settings on the printer. Set to DHCP for address and reboot the printer. This should ensure the machine is getting it's IP address from your router. Recheck the IP address and subnet mask are in the same range as your computer and router and try a test print. If that does not work - manually set an address in the printer with a terminal value of 50 eg 192.168.0.50. Try that. If still no good, reset the printer IP to DHCP automatic and reboot the entire system. Please note if you are using Apple/Mac portable computers - your IP address range may change every time you boot in a different location.
Canon PIXMA ... | Answered on Dec 06, 2017
Sounds like a carriage issue and unfortunately you can buy that printer new for less then it costs to get a new carriage put in
Canon PIXMA ... | Answered on Nov 13, 2017
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
1,270 questions posted
Clive
Clive
old marine
old marine
Ekse
View Most Popular
PIXMA Canon
  • PIXMA Canon
Most Popular Question
error inner cover open
  • Office Equipment & Supplies
