HP Officejet 6310 All-In-One InkJet Printer Logo
Posted on Dec 28, 2010
It indicates that there is a paper jam but there is no paper jam
annie ross
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 20, 2019
annie ross
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
242
Points
Solution: Reset printer is the best option to resolve paper jam problem. So look at below steps how to reset:
- Turn on the printer.
- Disconnect the power cord from your printer
- After disconnecting, unplug the power cord from the outlet
- Wait for few seconds i.e. 60 seconds
- After completion 60 seconds, plug power cord into an outlet
- Reconnect the power cord to your printer
- Turn on your printer, may your issue resolved.
Anonymous
Level 1:
New Friend:
  • Contributor 23 Answers
  • Posted on Dec 28, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
23
Questions
Helped
18513
Points
52
This issue may cause due to the following reasons.
1. Unlocked rear access door.
2.Dirty paper feed rollers. Over time, paper fibers and dust will stick to the rollers
3.Partially installed paper tray.
4.The paper is being pushed in too far.
However, to resolve the issue I have included the troubleshooting steps, which are ranked by simplicity and probability of success.
We truly appreciate the trust that you have displayed in us and our service and assure you that we will certainly live up to your expectations.
Solution summary:
* Paper jam (article)
* Supported paper
* Check the size of the paper / check with different paper
* Check the number of sheets loaded
* Cleaning the rollers
* Power cycle
* Connect directely to wall out let
* Semifull Reset
Paper jam:
Instead of sending this document in a text format, we are referring you to the Web link clearing the paper jam, where this information is easier to read with graphics.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00668030&cc=us&lc=en&dlc=en&product=1119598&tmp_track_link=ot_search
NOTE: Clicking the link above may give an error indicating it is invalid. If this occurs, copy the portion of the address on the remaining line(s) and paste it at the end of the address showing in your browser until the complete address is displayed in the Address box.
Supported paper:
Instead of sending this document in a text format, we are referring you to the Web link for using the supported paper, where this information is easier to read with graphics.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00608729&cc=us&lc=en&dlc=en&product=1119598&tmp_track_link=ot_search
Check the size of the paper/ check with different paper:
Ensure, that you are using correct size, and thickness of the paper, if the error message still appears, check with other paer.
Check the number of sheets loaded:
Ensure, that minimum number of sheets are load, try to load single sheed and try printing.
Cleaning the rollers:
1. Unplug the printer power cord and remove the back door.
2. Wipe the paper rollers with a lint-free cloth lightly moistened with distilled or bottled water. Rotate the rollers with your fingers to clean all the way around.
3. Allow the rollers to dry completely, then close the rear door.
4. Open the print carriage access door.
5. Use a soft cotton swab dampened with water to clean the four small metal paper rollers. Avoid touching the encoder strip. The illustration below shows the relative locations of these parts.
6. Use a clean, dry cotton cloth to wipe the carriage rod. Move the carriage as needed to clean the full length of the rod. Do not lubricate the rod.
7. Close the printer, plug the power cord in, and turn on the printer power.
8. If the error message does not go away, you need to get the printer serviced.
Power Cycle:
Follow the steps below to power cycle your all-in-one:
1. Verify that the unit is switched on. Disconnect the USB/Ethernet cable from the All-in-One and also disconnect power cable from All-in-One and also from wall outlet.
2. Wait 30 seconds.
3. Plug in the power cable to All-in-One and also to wall outlet.
4. Check for the functionality.
Connect directely to wall out let:
The surge protector may not supply sufficient power to the printer. To isolate the issue please remove the power plug of the printer from the surge protector and connect it to the wall jack directly.
Being a All-in-One Machine it needs full voltage to be supplied while initializing Surge protectors supply suppressed voltage to the printer which leads to unexpected issues in the printer
Semifull Reset:
Note:
A semi-full reset will do the following:
The user settings to the factory defaults, Language and country settings on some models, Fax logs, Fax headers, Fax speed dial information.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
Now check the functionality,
Please feel free to reply us. It is our responsibilityto serve our esteemed customers like you in the best possible way. We appreciate your support and cooperation.
We value our esteemed customers and your satisfaction is very important to us. Customer service and satisfaction are at the top of our corporate goals.
We are always available round the clock to assist you technically regarding the problems you may experience with All-in-One.
Thanks & regards
Pradeep Kumar
1helpful
Paper jam indicates but there is no jam
Please try to clean the paper feed rollers.
Gympac 1600 manual
Device error An internal error occurred in the device. Press (Select) to resume the job. - Door open The printer door is open. The door must be closed before printing can continue. - Engine comm. error The device experienced an internal communication error. This is a warning message only. Job output might be affected. - Invalid driver You are using the incorrect printer driver. Reselect the printer driver appropriate for your device. - Invalid entry Invalid data or response. Correct the entry. - Jam in Cartridge area A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel - Jam in Output bin A paper jam has occurred in the output area. Clear the jam, and then press the (Select) button on the control panel. - Jam in print paper path. A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel. - Jam in tray 2 A paper jam has occurred in Tray 2. Clear the jam, and then press the (Select) button on the control panel. - Jam in tray 3 A paper jam has occurred in Tray 3. Clear the jam, and then press the (Select) button on the control panel - Load paper The HP Color LaserJet 1600 printer is out of paper. Please load specified paper type into the tray indicated. - Load Tray X [TYPE] [SIZE] The printer is processing job, but the tray indicated is empty. Please load specified paper type and size into the tray indicated. - Manual feed The printer is waiting for paper in the tray indicated Load the paper as indicated. - Memory is low The device memory has been almost completely filled. Allow the device to finish the job, or press (Select) to cancel the job. Break the job into smaller jobs that contain fewer pages. - Misprint The printed pages have been incorrectly placed on the paper. To continue, press the (Select) button on the control panel.
Paper jams at toner cartridge, printer service maintenance kit installed
Paper Jam clearing: copy and paste the link in your web browser...I used to work with these printer's..when they work great, when they don't, not so great..
https://www.manualslib.com/manual/949165/Hp-Laserjet-5000.html?page=84
Clearing Paper Jams If the printer's control panel displays a paper jam message, look for paper in the locations indicated in Figure 22, then see the procedure for clearing the paper jam. You might need to look for paper in other locations than indicated in the paper jam message. If the location of the paper jam is not obvious, look first in the top cover area.When clearing paper jams, be very careful not to tear the paper. If a small piece of paper is left in the printer, it could cause additional jams. If paper jams are a recurring problem, see page 78.(A paper jam message might also display if the rear door is open.)
The top cover of the printer must be opened and then closed to clear a paper jam message.Paper jams can occur at the following locations:Output areas(top and rear)Go to page 75.
Loose toner might remain in the printer after a paper jam, but thetoner should clear after a few sheets are printed.
I have a Brother Printer HL-240D that gives me a constant paper jam inside indication even though the paper goes completely through the printer, and there is no actual paper jam. What switch causes the...
Have you tried shutting it down completely? Also, double check to see if the inside of the printer is completely clean. I had the paper jam indicator showing because there a small piece of paper stuck inside. Also, found a helpful manual for a similar printer, you can see it here - Brother HL-2240 manual
Paper feeds about half way and then stops. All of the indicator lights come on.
If you get a paper jam, the Paper Jam indicator light promptsyou to clear the paper path. If the paper has just started to feed from thepaper feeder when the jam occurs, pull the paper straight up out of the paper feeder. Open and close the printer cover toresume printing. If the paper jam occurs inside the printer, remove the paper from the output bin. Turn the printeroff, then on. If this doesn't clear the jam, open the printer cover.Remove the print cartridge and cover it.For additional assistance, please contactLexmark Technical Support
1helpful
Canon mx310 indicates paper jam but no paper
The printer has several switches in it to detect paper jams. When paper feeds in it trips the first one indicating that paper is present. Another switch further along the feed path indicates that the paper is feeding okay.
Your problem can be a jammed switch (loose scrap of paper), a broken switch, a switch disconnected from the controller board or a possible bad controller board.
One thing you didn't mention was does it respond the same with paper loaded? It might be that the first switch is looking for some and not finding it, so it is programmed to assume a jam.
I have a paper jam on a CLC 1120 and there is no paper jam I've check the machine 10 times
You didn't state where the jam is indicated. If it's indicating a paper pickup jam there are levers toward the back of the cassette that could get hung up.If it's a fuser jam the outlet lever on the fuser unit.If it's indicated in the transfer drum area a bad transfer sheet can give a false jam indication sensing paper on the drum.
Kyocera 3900dn says paper jam in rear but no jam evident
Usually a printer doesn't lie when it indicates a paper jam, if you have checked as thoroughly as possible and no paper can be found. It is possible that the paper just isn't feeding and a printer will sometimes indicate a paper jam when paper doesn't feed. But if this isn't the case and a jam is indicated as soon as you turn the printer on, one of the plastic jam sensing actuators may be broken or hung up.
k24674
Grand Canyon Tech
Grand Canyon Tech
