20 Most Recent HP Officejet 6500 Wireless All-in-One InkJet Printer Questions & Answers
call for Free printer Support. Call Toll Free Phone Number - 877-690-9305
HP Officejet... | Answered on Jun 04, 2019
Check this repair tip out. Works for me almost everytime:
HP Officejet... | Answered on Jan 30, 2019
This is a common error, but usually can be fixed without replacing any parts. See video:
1. Plug it directly into the wall, rather than into a UPS
2. Verify that the unit is switched on. Disconnect the USB/Ethernet cable from the All-in-One and also disconnect power cable from All-in-One and also from wall outlet.
3. Wait 30 seconds.
4. Plug in the power cable to All-in-One and also to wall outlet.
5. Check for the functionality.
I still had the error message, so they said to reset the printer to factory default settings:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
If those two steps do not resolve the problem then its is hardware related and can't be solved here.
Try this. It worked for me a few times:
Here are a few suggestions or tips on how to fix this issue:
General error 0x610000F6 actually is a Carriage Jam issue
Click Here for troubleshooting.
I’m happy to help further over the phone at https://www.6ya.com/expert/jonathan_828b54f422cbefdd
Download the manual for HP 6500,
HP OfficeJet 6500 Wireless Manual.
It is clearly mentioned in it.
-Rate if it helped you.
HP Officejet... | Answered on Oct 01, 2018
Software (driver) can be found at driverupdate us.
Take a look... I hope this was helpful.
Cheers
HP Officejet... | Answered on Sep 17, 2018
Hello
Same problem for me. found a procedure to get back to Service Menu which works for HP 8600 :
https://h30434.www3.hp.com/t5/Printers-Archive-Read-Only/X476dw-doesn-t-boot-Help/td-p/5044674
1. Unplug the power cord (!)
2. Insert power plug while keeping power button pressed.
3. While the HP logo appears on the screen, keep the button pressed. The screen will go dark. KEEP THE BUTTON PRESSED for another 5-10 seconds.
4. Let go of the button. The screen remains black.
5. Push Home-Back-Home-Home button. The buttons are usually not visible, so refer to the manual, where they are on the touch screen. (Home is left of the upper left corner of the touchscreen, Back is left of the lower left corner)
6. A blue menu comes up, with four choices.
7. MENU on the lower right has a FULL RESET option.
HP Officejet... | Answered on Sep 12, 2018
You use the Copy button to get to Reduce/Enlarge. It will offer different sizes (i.e. actual size, full page 91%, custom 100%, etc.) you enter OK at the Custom 100%, then you can enter whatever % you want up to 400. I hope this helps.
HP Officejet... | Answered on Aug 14, 2018
1-800-281-3707 is the Number of HP Printer Technical Support Phone Number. get Instant HP support by Dialing this Toll Free Number. We Provide HP Printer Technical Support Phone Number -800-281-3707 for fixing HP 6500 printer.
HP Printer Support Number 1 800 281 3707HP Printer Technical Support
HP Officejet... | Answered on Aug 11, 2018
first of all.. make sure that you remove the packing material from the cart or print heads and put them in properly.
then also if it it gives the same probem then try it with the old print heads.. if it doesnt gives any eror with the old ones then replace the new ones..
new ones are bad..
return them to store
HP Officejet... | Answered on Apr 05, 2018
Send the cartridges back! HP cartridges are coded and will only work with HP printers. Hp has had problems with their coded cartridges. Especially if they were manufactured overseas. Their own product won't recognize the cartridges. It is not the printer it is the cartridges.
HP Officejet... | Answered on Feb 18, 2018
Get the Diagnostic download for your 6500 from HP.com. It will trace the problem for you. Check you power supply to see if it is operational. Press all connections in tight.
HP Officejet... | Answered on Feb 04, 2018
reboot (unplug) both the mac and the printer. happen to my imac and 7620 at least once a week
HP Officejet 6500 Wireless All-in-One InkJet Printer Logo
1,534 questions posted
Clive
Clive
Thomas F. Schneider
View Most Popular
OfficeJet HP
  • OfficeJet HP
Most Popular Question
hp solution center software
  • Office Equipment & Supplies
