20 Most Recent
Lexmark Optra E312L Laser Printer Questions & Answers
Paper feeds about half way and then stops. All of
If you get a paper jam, the Paper Jam indicator light promptsyou to clear the paper path. If the paper has just started to feed from thepaper feeder when the jam occurs, pull the paper straight up out of the paper feeder. Open and close the printer cover toresume printing.
If the paper jam occurs inside the printer, remove the paper from the output bin. Turn the printeroff, then on.
If this doesn't clear the jam, open the printer cover.Remove the print cartridge and cover it.For additional assistance, please contactLexmark Technical Support
It wont print. file
Please try to do the following steps
-Double check physical connection, make sure cableconnecting the printer and computer is connected properly.
-Check on device manager if printer is detected by thecomputer
-Try to use a different port or use a different cable.
-Please check if the printer is set as the defaultprinter.
- Try to use a different driver.For additional assistance, please contactLexmark Technical Support.
MY PRINTER ALL LIGHT BLINK
The light indicates that there is an error on the printer and it will immediately stop printing. Turn the printer off and back on. Cancel all print job. If the lights are still blinking, please contact Lexmark Technical Support for additional assistance.
I have lexmark e312 printer
We would like to know what is the current driver that you are using? please provide us information so that we can properly isolate the problem.
For further assistance, please contact Lexmark Technical Support.
Our sheets are coming out
I assume you mean the whole page itself is coming out black? This is usually a sure sign of a problem with the charger corona wire. Either it is broken or not making good electrical contact. Having you tried an engine clean cycle? Try your basic troubleshooting, also try uninstalling and reinstalling the toner cartridge. Otherwise your unit is most likely in need of repair by a professional. In that case you will want to inquire about an estimate and consider whether repair or replacement is your best option as a comparable laser printer is quite affordable now. If you have any other questions please let me know.
Thank you,
Lee
The E312 is printing pages
Normal
0
Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off.
I'd do both and reinstall the CD software program that came with
the printer. When the software program asks you to connect the
printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Paper feed
Hi seems to me that the paper feed separation pad is not in the correct place check and clean this should help if not get back to me.
Thanks J
LEXMARK OPTRA E312L DOES NOT PRINT
Just to determine if the problem is a printer or PC problem, try pressing the button at the bottom of the lights 3 times quickly and see if it prints out a test page. If it does then try reloading the driver on your PC.
PRINTER SHOWS NO PAPER IN DRAWER
There is a sensor that detects paper just after the paper tray. No matter what is the reason that paper doesn't reach the sensor your printer will indicate that there is "no paper".
You should check is something preventing transport system even to reach the level of paper. In the case of Lexmark E342 or E250 printers, for example, two wheels with black rubbers rotating around common axis are pushing the paper . When you pull out the paper tray the transport system with rollers can be seen from the bottom side of the printer. If the rollers are not laying on the surface of the paper they can not push it inside the printer.
If you are sure that it is not the case the next thing you should check is the rubbers mentioned above. They must be clean enough to have efficient traction with paper. You should take the rubbers off the wheels, wash them with water and soap, rinse them and thoroughly dry. Put them back and try.
What can replace the ibm lexmark wheelwriter 1000
If you're looking for a replacement for the IBM Lexmark Wheelwriter 1000, you might consider a typewriter like the Brother M-1000, the Olivetti Studio 45, or the Smith Corona SR8000. These typewriters have similar features and capabilities to the Lexmark 1000, and they're often considered to be good alternatives.
