20 Most Recent
HP LaserJet 5000n Printer Questions & Answers
Paper jams at toner cartridge, printer service maintenance kit installed
Paper Jam clearing: copy and paste the link in your web browser...I used to work with these printer's..when they work great, when they don't, not so great..
https://www.manualslib.com/manual/949165/Hp-Laserjet-5000.html?page=84
Clearing Paper Jams If the printer's control panel displays a paper jam message, look for paper in the locations indicated in Figure 22, then see the procedure for clearing the paper jam. You might need to look for paper in other locations than indicated in the paper jam message. If the location of the paper jam is not obvious, look first in the top cover area.When clearing paper jams, be very careful not to tear the paper. If a small piece of paper is left in the printer, it could cause additional jams. If paper jams are a recurring problem, see page 78.(A paper jam message might also display if the rear door is open.)
The top cover of the printer must be opened and then closed to clear a paper jam message.Paper jams can occur at the following locations:Output areas(top and rear)Go to page 75.
Loose toner might remain in the printer after a paper jam, but thetoner should clear after a few sheets are printed.
Printing colored lines
Vertical black lines:Check with another cartridge..Check Teflon sleeve.Vertical white lines:Replace cartridge.. replace transfer roller..Clean laser scanner unit( technical skills required) Horizontal Black lines:Replace cartridge..
My HP LaserJet 5000N will
normally you will need to let the printer know that you have preformed any maintenance on it by clearing the error count after such an error occurs and is fixed it is normally listed under general or service options on the printer menu but you may need to look through the users manual
hope this helps
Robb
My printer hp leserjet color 5000n is not
I use a clear silicone tube to carefully prime the carts by sucking a
dab of ink out of the tiny print holes before installation. I am careful to have a tight seal at the holes to prevent getting too much ink and possibly getting it in my mouth.
I am trying to print
Hi, the envelopers are jammed because, when its go inside that time the extra paper which is use for sticking that sucked by the roller & the paper is jam. Be careful when you press start button for copy that time make sure the envelops open face is secure & not have a chance to trapped inside. Otherwise your process is perfect. Thanks & waiting for your feedback.
I have a HP laserjet 5000 that is printing light.
Let's try going to the control panel and go to PRINT QUALITY/ECONOMODE=ON.
TONER DENSITY=5.
Now run some pages through.
If pages are good change the density to 4 and try again. If that didn't help, then you could be looking at "transfer roller","engine control board", "laser scanner", "high voltage supply".
IT IS OFFLINE I WANT IT ONLINE
1. Go to Control Panel
2. Double click on Printers and Faxes or Printers
3. Right click on the printer icon
4. Select "User printer online"
