20 Most Recent
Kyocera FS-3900DN Laser Printer Questions & Answers
Error code 7410:0095606 How can I fix it?
Drum unit non- installing error
The drum unit is not installed or not installed properly. You must have knocked it loose.Install the drum unit (See page P.1-5-10).
10/8/2019 4:53:13 PM •
Kyocera...
Answered
on Oct 08, 2019
Error call service 4000:00433933
i have 7410 error call service. i tried to clean everithing en replaced the tone is almost full- still getting the error message.hat can i do. (fs-3900dn)
9/17/2018 6:06:38 PM •
Kyocera...
Answered
on Sep 17, 2018
Triumph-adler DC 2018 error C6000
Defective Fixing Unit... Poor contact in the thermistor connector terminals, bad thermistor, broken heater lamp wire or some other contact problem related to fixing section. If it is possible, check with another Fixing Unit.
3/20/2018 12:25:31 PM •
Kyocera...
Answered
on Mar 20, 2018
Call service 6000:0098269
6000 Broken fuser heater lamp wire
The temperature does not reach 100°C/
212°F after the fuser heater lamp has
been turned on continuously for 30 s.
30/31 ppm printer (EUR/USA model):
The temperature does not rise by 1°C/
1.8°F after the fuser heater lamp has
been turned on continuously for 5 s during
printing.
35/37 and 45/47 ppm printers (EUR/USA
model):
Fuser thermistor M detection
temperature does not rise by 1°C/1.8°F
after the fuser heater lamp has been
turned on continuously for 10 s during
warm-up or at standby.
Fuser thermistor S detection
printing.
Poor contact in the
fuser thermistor M
connector terminals.
Reinsert the connector (See page P.1-5-19).
Fuser thermistor M
installed incorrectly.
Check and reinstall if necessary (See page
P.1-5-19).
Thermal cutout
triggered.
Check for continuity. If none, replace the
thermal cutout (See page P.1-5-19).
Fuser heater lamp
P.1-5-19).
Broken fuser
heater lamp wire.
fuser heater lamp (See page P.1-5-15).
1/23/2017 8:10:17 AM •
Kyocera...
Answered
on Jan 23, 2017
Laser jet printer
call service 74101:0071621
Error 7410 is drum unit not installed properly if you open the side door and push the the drum unit back in to place it probably just popped out of position a little bit
4/11/2015 11:52:15 AM •
Kyocera...
Answered
on Apr 11, 2015
Kyocera service code 7410:0013781
Drum unit non- installing error The drum unit is not installed or not installed properly. The drum PWB EEPROM does not communicate normally.
3/16/2015 11:11:55 PM •
Kyocera...
Answered
on Mar 16, 2015
7410: 0178137
Power off the printer, open left door and press in the drum unit (press in the area just above the square button) until it clicks into place. Close the door and power on.
10/30/2014 1:22:05 AM •
Kyocera...
Answered
on Oct 30, 2014
Prints black background, white letters
sounds like invers is turned on which switches everything black will be white and white will be black try to find this seting and turn it off
8/21/2014 7:18:19 AM •
Kyocera...
Answered
on Aug 21, 2014
Command center admin user
are you asking for the password the default passwords are either Admin or admin00 that is for the web page on the machine its usally Admin or the speed of the mACHINE PLUSE TWO zeros
8/11/2014 1:00:11 PM •
Kyocera...
Answered
on Aug 11, 2014
7410 : 0674421
Open the left cover and push the drum unit inside (above the waste toner bottle) to lock. You will hear a sound like "click". If you cannot push the drum unit, you can first remove the developer unit.
7/22/2014 4:48:46 PM •
Kyocera...
Answered
on Jul 22, 2014
PRINTER IS PRINTING BLACK PAGES AND WHITE CHARACTERS
It might be the main charger (MC-310 or MC-320) or the ground of the developer unit. In the first case, just remove the roller from the drum unit and clean it. In the second case, you have to remove the engine pwb (the board under the printer) and check the spring which grounds the developer unit.
7/15/2014 4:44:14 PM •
Kyocera...
Answered
on Jul 15, 2014
Kyocera 3900DN Error Code
F030 General failure
Miscellaneous failure with the main
PWB, other than F000, F010, F020,
F040 and F226, above.
Defective main-PWB
Turn the power switch off/on to restart the
printer.If the error is not resolved, replace
main PWB
4/30/2014 4:24:55 PM •
Kyocera...
Answered
on Apr 30, 2014
