Hi and welcome to FixYa. I am Kelly. On your cook-top the gas igniters are cycled on and off by a ceramic and copper switch on the front of each of the gas valves. Some of them are in wired Series ...i.e any burner on will cycle all igniters on the cook top and some of them are in Parallel where individual burners are controlled by each gas burner control knob. Inside these tiny ceramic switches there is a flat thin strip of copper that as the gas valve is rotated a cam of the switch actuates pushes the copper strip against the fixed contact. Those little strips over time either break or get bent and stay against the fixed contact. Hence you have and igniter on when the burner control is off. The only fix is to find out which little ceramic switch on the front of the gas valve is stuck. You do it with an Ohm meter POWER off. They all should read open with the burner controls off. The one that reads continuity across the 2 wires is the bad switch.
Thanks for Choosing FixYa.
Kelly
SOURCE: maytag stove top gas ignitor keeps clicking
clean the bottom of the knob by using vaccium,remove the knob,pull it then clean the area of the control knobs.
