Jenn-Air 34 in. Expressions CVGX2423 Gas Cooktop
Take a brief Survey Take a brief Survey   Add to My Products Add
Problems with Jenn-Air 34 in. Expressions CVGX2423 Gas Cooktop?
Troubleshooting and Support
Solved Problems for Jenn-Air 34 in. Expressions CVGX2423 Gas Cooktop RSS Feed Post a New Problem
Jenn-Air Expressions cvgx2423b manual...
I have a Jenn-Air Expressions cvgx2423b model with the same problem of one burner not working and have reviewed the...
1 Solution
keeps clicking after lit
keeps clicking after burner has lit (all 4) doesn't do it all the time
2 Solutions
stove top [gas] JENNAIR
my gas stove top igniters keep ingniting when turned off
1 Solution
Ignitors all quit working.
Model # CVG2420B They all worked perfect, they all quit at once. The exhaust fan works great, the cook top is plugged...
1 Solution
Jenn-Air Gas stovetop
One of our burners has a very low flame even when turned on high.  The other burners work fine.  This...
1 Solution
Jenn-Air Gas Cooktop Model CVGX2423
All ignitors on my Jenn-Air Cooktop (model CVGX2423) continue to spark for a long period (even when only one burner is...
3 Solutions
Switch assembly
i read your fix for the igniter not turning off, but where is the switch assembly
1 Solution
Unsolved Support Problems
Unsolved Problems for Jenn-Air 34 in. Expressions CVGX2423 Gas Cooktop RSS Feed Post a New Problem
Same model number as above
Fan will not turn off. Need a new fan switch. Where do I find a diagram to repace. Is it easy?
Post a Solution
gas stovetop flame pattern
I have a gas cooktop and the tips of the flame are a yellow/orange color instead of the blue at the base of the flame....
Post a Solution
Jen-Air Gas range Igniter keeps clicking...
We have an Jenn-Air gas range, it has the problem that it's getting difficult to start the fire while the igntter keeps...
Post a Solution
Igniter
All other igniter keep making spark and noice when any burner turned on.
Post a Solution
Filter does not fit fluslly agains fan -...
There is a small gap where the filter meets metal
Post a Solution
Jenn Air Stove Top
Larger of four electric stove top (Jenn Air) overheats. Can a repairman fix this or do I need a new stove top? Joseph M...
Post a Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
Fuel TypeGas
Number of Cooking Elements4
Element TypeBurner
Cooktop TypeFixed
Dimensions
Overall Depth21.13 in.
Overall Width34.13 in.
Warranty
Warranty1 Year
Jenn-Air Contact Information
Main support number1-800-688-1100
Sponsored Links
Loading problems.
Top Kitchen Cooktop Experts
Bob from
4 solutions
Large Appliances, Small Appliances
Ask Me
Guru
Amigaman
1 solutions
Large Appliances
Ask Me
Guru
sandrew
1 solutions
Operating Systems, PC Desktops, PC Laptops...
Ask Me
Wiz
Repair Service
Find Kitchen Cooktop Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
