20 Most Recent
General Electric GE Monogram 48"" Professional Gas Rangetop with 6 Burners and Gri Questions & Answers
My GE Monogram gas range will not light. The igniter keeps going off but the gas will not light.
Hi, sometimes cooking spills stop the ignitor from working. Clean the cook top thoroughly and try it again. Spills can also make the ignitor go off randomly when you are not operating your cooker. Check if the ignition point where the zap comes from is not turned or bent too far from its original position. If you have a gas shut off make sure it is fully open to supply enough gas. If all else fails buy a cheap hand held ignitor to start your gas stove. If the cause is a spill which sometimes the problem can persist even after cleaning it may take a while for it to work again. If the problem is with all six burners then your ignitor probably needs replacing. When you hear the ignitor zap check to see if the electronic zap appears to jump across to the edge of the burner. If it doesn't it will not light the flame no matter how many times you try. I hope this helps you.
My defy slimline cooktop shows ER42 but I changed the capacitors, what is wrong?
The ER42 error code typically indicates an issue related to insufficient power being delivered to the ceramic element.
Check Power Supply: Ensure that the cooktop is receiving adequate power. Verify that the power supply is stable and not fluctuating.
Inspect the PCB (Printed Circuit Board): Since the error points to a fault on the PCB, visually inspect the control board for any signs of damage, loose connections, or burnt components.
Capacitors: You mentioned that you've already changed the capacitors. While this is a good step, it's essential to ensure that the new capacitors are correctly installed with the same rating and polarity.
Reset the Cooktop: Turn off the power to the cooktop completely. Disconnect it from the mains for a few minutes, then reconnect it and power it back on. Sometimes, a reset can clear minor glitches.
No joy? Consider professional repair.
4/21/2024 5:08:45 PM •
Cooktops
Answered
Yesterday
I can't lower the heat on my Whirlpool electric stove cooktop. Started about a month ago. Stove is 15 yrs old. Everything else on the stove works e
It needs a new control if it has dials or a control pad or a part if it is electronic. Full make and MODEL (what it is) in all answer please as first 3 words in every question.Edited as model number given Whirlpool GFE471LVShttps://www.whirlpool.com/owners-center-pdp.GFE471LVS.htmlThe Infinite Switches are $130, so it is best to test them with a multimeter first.https://www.partswarehouse.com/Whirlpool-GFE471LVS0-Freestanding-Electric-Range-s/131742.htmVideos showing how to changehttps://www.google.com/search?q=whirlpool+gfe471lvs+replace+hob+infinite+switchOwner Manual, just because it was therehttps://www.manualslib.com/products/Whirlpool-Gfe471lvs0-10479409.html..
4/6/2024 6:50:10 PM •
Cooktops
Answered
on Apr 06, 2024
Jenn Air C221 element only goes to high?
Based on the symptoms described, it is possible that the issue lies with the ceramic element that the burners connect to at the back of the burner unit. This could be causing a short circuit between the two burners, which is preventing the large burner from being adjusted lower when both burners are on.
It is also possible that there is an issue with the wiring or connections between the two burners, which is causing a similar short circuit. However, given that the smaller burner appears to be working fine, this seems less likely.
Another potential cause of this issue could be a problem with the control board or another component of the stove's electrical system. However, given that replacing the infinite switch and receptacle for the large burner did not resolve the issue, it seems less likely that this is the root cause.
In order to determine the exact cause of this issue, it may be necessary to consult with a professional appliance repair technician who can diagnose and repair the stove.
6/21/2023 9:17:30 PM •
Cooktops
Answered
on Jun 21, 2023
Domain ceramic cooktop cec70 will not turn off
If your ceramic cooktop model CEC70 is not turning off, there are a few steps you can take to troubleshoot the issue:
1. Check the controls: Ensure that you have properly followed the instructions to turn off the cooktop. Some models may require you to press and hold a specific button or combination of buttons to power off the cooktop. Refer to the user manual for your specific model for detailed instructions on turning it off.
2. Power cycling: Try power cycling the cooktop by turning off the power at the circuit breaker or unplugging it from the power source. Leave it unplugged or with the power off for a few minutes before plugging it back in or turning the power back on. This can sometimes help reset the controls and resolve any temporary issues.
3. Control lock: Check if the cooktop has a control lock feature that might be activated. Some models have a lock function to prevent accidental changes to the settings. Look for a button or key combination that activates or deactivates the control lock. Refer to the user manual for instructions specific to your model.
4. Contact customer support: If the issue persists, it is recommended to reach out to the manufacturer's customer support or consult a professional technician who specializes in appliance repairs. They will be able to provide further guidance or arrange for a service visit to diagnose and fix the problem.
Remember, when dealing with electrical appliances, it's always important to prioritize safety. If you encounter any unusual or potentially hazardous situations, such as smoke, sparks, or strong odors, immediately turn off the power supply and contact a professional technician for assistance.
6/19/2023 9:27:30 AM •
Cooktops
Answered
on Jun 19, 2023
