20 Most Recent
GE 36 in. JGP628 Gas Cooktop Questions & Answers
Ticking Sound of spark igniter persists
Our GE cook-top burner igniter has started ticking even when the oven is shut off. Even after cleaning the bottom of controls the ticking persists. Any suggestions? Thanks
When I attempt to light
Hi
Some of the probable causes to your problem are:-
Blow into the little holes where the gas comes out.sometimes they get clogged with water after washing them or something is spilled on them. sometimes this is the solution.
If ithe spark gap on the igniter is plugged with food, clean it with a small brush and rubbing alcohol. Do not scrape.
On some ranges if the burner is rotated when cleaned and is in the wrong position, it will not light.
Or a cracked electrode ignitor or bad wire to the ignitor can stop/prevent the spark from sparking at the correct spot and lighting the burner.
Sometimes the problem is a bad ignition switch too.
Also check this link :-
http://www.ehow.com/how_6682025_troubleshoot-stove-oven-won_t-light.html
Please accept the solution if it’s helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
The igniter doesn't work at
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
Here is a tip that I wrote to give details about why your cooktop will not
spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
All 4 electrodes spark when only one is turned on
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good "blue" arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
We havent purchaced this cooktop yet but are
It would be a good idea to plan for an outlet for the cooktop. most do use 120 volts for the spark device. Locate it behind or below the cooktop so it will not be confused with your countertop outlets.
Please Vote !!
