20 Most Recent Bosch 36 in. NGT 935 Gas Cooktop Questions & Answers
0answers
0answers
On a gas bosch stove
unplug the stove and plug it back in. if it keeps ticking, your spark module is going bad
2/5/2011 2:13:44 AM • Bosch 36 in. NGT... • Answered on Feb 05, 2011
Electronic igniters won't shut off.
Boy, I had a Thermador that used to drive me bats.
The best solution was to clean around the ignitor pin and make sure the orifices closest to the ignitor are not blocked... It made a big difference.
I used a small fine metal bristle brush.. did the trick.
5/30/2009 2:32:11 AM • Bosch 36 in. NGT... • Answered on May 30, 2009
Stains from cleaning products?
Bosch (BSH appliance care) do a stainless steel conditioner you could try. I think its called Starglanz.
3/29/2008 8:41:28 AM • Bosch 36 in. NGT... • Answered on Mar 29, 2008
Bosch induction not working
Very specialised high tech tops need engineers to fix. It is likely to be the power board. https://www.google.com/search?q=Schott+Ceran+stove+top+with+5+induction+hobs+no+power ..
12/9/2023 7:11:31 PM • Bosch Cooktops • Answered on Dec 09, 2023
Bosch oven display does not work at all but the cooktop works. what is the problem?
There could be a few different reasons why the display on your Bosch oven is not working, but the cooktop is functioning properly. Some possible causes include:
  1. A problem with the control panel: The control panel is responsible for controlling the oven and displaying information on the screen. If there is a problem with the control panel, it may be preventing the display from functioning properly.
  2. An issue with the oven's electrical system: If there is a problem with the oven's electrical system, it could be causing the display to malfunction. This could be due to a problem with the wiring, a faulty component, or a power issue.
  3. A problem with the display itself: It is also possible that there is a problem with the display itself, such as a damaged screen or a malfunctioning component.
In order to determine the cause of the problem and fix it, you will likely need to have the oven inspected by a professional appliance repair technician. They will be able to diagnose the issue and recommend the appropriate course of action.
1/6/2023 11:01:32 PM • Bosch Cooktops • Answered on Jan 06, 2023
Bosch Induction cooktop#NIT8665UC error code 3d or d3 at burner indicator
Did you ever get an answer to this? Same problem :(
7/27/2021 10:11:29 PM • Bosch Cooktops • Answered on Jul 27, 2021
2answers
Bosch induction cook top flashing F 9 snd will not work
https://www.fixya.com/support/t27212586-f9_code_flashing_bosch_induction_cook
1/24/2021 6:24:32 PM • Bosch Cooktops • Answered on Jan 24, 2021
Bosch 36 in. NGT 935 Gas Cooktop Logo
16 questions posted
Top Bosch Cooktops Experts
Paul Carew
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Are you a Bosch Cooktop Expert? Answer questions, earn points and help others
View Most Popular
Bosch Cooktops
  • Bosch Cooktops
Most Popular Question
gas bosch stove
  • Cooktops
