Washer fills correctly and agitates very
well. When the timer reaches the spin cycle it starts very slow and if left operating the tub remains almost full. I chacked the pump and it is operating. I removed the lid safety switch and connected the wires together and the operation remeined the same. After trying everything else I turned the waher off, moved the dial a little and turned it on again the spin cycle worked well and the tub drained completely. This has to be done for both spin cycles and requires standing in front of the washer all the time. Cuould this be a faulty timer or a faulty timer switch? Can the timer switches be replaced?
SOURCE: Maytag LAT9706AAM Washer - Spin Cycle problems
If the timer is advancing but won't spin out, it is possible that the spin contacts inside the timer are faulty. A technician will normally isolate and confirm this diagnosis witth a special power cord hookup to the motor. From the way you describe your complaint, I feel that a timer would correct your problem.
Hope this advice is helpful!
SOURCE: Agitation issues. Everything else appears/works normally.
I just encountered the same problem. I think the operation of the machine is such that the motor turns one direction for the spin cycle, and the other direction for the agitate cycle. I am replacing my motor, as I think i have a bad winding on the reverse. I will let you know.
SOURCE: not spinning after wash cycle
remove the 2 console screws one on each side of front or they may be on the back of console,flip it up and you will see the lid switch jack on the washer in the middle,unplugon the washer side you want two cut the 2 outside and wire nut them together,this will by pass the lid switch,plug back in,put console back and you should be good to go-mike
SOURCE: maytag washer won't fill or agitate; only spins on cycle
sounds like you have a blown fuse. I dont have a schematic so I dont kno where you have to look to find it
