20 Most Recent Whirlpool Ultimate Care II LSQ9549L Top Load Washer Questions & Answers
remove 2 screws on rear of console lift console forward and roll back remove the lid switch connector remove the 2 clips on each side pull rear of cabinet forwardand slide cabinet off remove screws in center of agitator under cap and pull off ..lean washer backward remove pump clips and hoses remove 2 screws in motor clamps remove clamps and motor remove 3 1/2 in bolts holding gearcase to bottom slide gearcase out remove clutch and reinstall on new gearcase if you go slow and take note reassembly not that hard
Whirlpool... | Answered on Oct 08, 2019
Most likely it is the spin tube bearing worn. Reguires some know how and special tools. Requires a major dismantle of the machine and usally I did these repairs in the shop. Bearing will eventually sieze over use and time. Labor will probably exceed the value of the machine.
Whirlpool... | Answered on Nov 05, 2018
could be some u left in one your shirt are pant that fell out in dyrer an caugth between the drum seal
Whirlpool... | Answered on Mar 23, 2018
check your temperature sensor near the inlet valve
Whirlpool... | Answered on Feb 17, 2018
Possibly a worn drive belt, or it needs tensioning.
Whirlpool... | Answered on Jan 10, 2018
Go to www.repairclinic.com and enter LSQ9549LW1. With luck, you will be presented with a list of common replacement parts and may be able to view a generic Whirlpool video showing disassembly.
Whirlpool... | Answered on Dec 09, 2017
most if not all washers have three phase motor fitted for the purpose of the torque that is required but will only run
on three phase electric supply , and so these motors are
externally fitted with capacitor and run on the principle of three phase , but once these capacitors start to brake down the electric motor fail to run .
you may have a capacitor doing down
Whirlpool... | Answered on Nov 25, 2017
Check screens on both hoses and on water valve. Clean as needed. Obviously you need to be sure you have water coming from house source.
Whirlpool... | Answered on Nov 04, 2017
Either the wire going to motor for non working speed is loose or damaged, or motor is bad. It could also possibly be timer not sending power to motor for that speed.
Whirlpool... | Answered on Sep 27, 2017
Defective lid switch is most likely causing problem
Whirlpool... | Answered on Sep 11, 2017
Your timer is causing the problem more than likely, valves , pump motor is working so your timer itself is not change it most of the jobs can be done by the homeowner they are a quick connect disconnect and maybe a screw or a catch holding it just look at it how it attached to the console and reattach it the same way
Whirlpool... | Answered on Aug 12, 2017
more likely from a hose........need lid off and a good torch
cheers
Whirlpool... | Answered on Aug 03, 2017
No spin, or lite spin try these: bare in mind that many times there is no spin it can be due to a clogged water pump so check it for debris and or broken propeller.
Other items to check Using a multi meter check for continuity the door switch, which when bad may not allow agitation or spin. Bare in mind the lid switch assembly can fail either mechanically or electrically.
Check the clutch, brake assembly and transmission, one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand.
Or try the hand test:
If no hammering sound has ever been heard out of this machine, one of the unofficial tests we professional appliantologists will do in the field is called the Hand Test. WARNING:This test is not sanctioned by Whirlpool Corporation; it involves bypassing safety equipment and then putting your hand on and near rotating machinery which could result in injury, dismemberment, disfigurement, disembowelment, mangling, hideous screaming, and a ****** *****. Proceed at your own risk! Have a nice day.
- put the timer on a spin cycle and open the lid- grab the inner basket with maybe 30% to 40% of your hand strength with your left hand
- turn on the machine and bypass the lid switch by depressing the lid switch with a key until the machine begins to spin
- if the clutch is engaging properly, the basket should immediately begin to spin and slip through your hand
- if it takes very little force to stop the tub from spinning, the clutch needs to be replaced.
Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either)
Next if belt driven check for a loose, worn or broken belt. And on some models there is no clutch but rather what is called a splutch. And a MODE shifter. These can go bad and effect the spin cycle.
On some front load models u may need to check the STATOR assembly.
The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Sometimes a no spin machine can be due to a plugged waterpump hose or obstructed water pump propeller. Check these by eye and hand. And in some models check with a meter for continuity and voltage.
LID SWITCH TEST- next step is toremove the cabinetand jumper the lid switch harness (tan to gray). Put the unit in spin and watch the shiny metal clutch disc that is on top of the transmission where the shaft comes out. If the machine starts and runs in spin, check to see if the disc is spinning. If it is, then the problem isnot in the gearcase- look for trouble in theclutch,
basket driveor the tub drive block
If, on the other hand, the disc is NOT spinning, check for a problem withthe motor drive coupleror one of its retainers. This washer doesn't have a belt. Instead, the motor is directly coupled to the gearcase by a drive coupler; that's why it's called a direct drive washer.
Read more:Diagnosing and Repairing Spin and Agitate Problems in a Whirlpool / Kenmore Direct Drive Washer
http://fixitnow.com/wp/2010/07/07/diagnosing-and-repairing-spin-and-agitate-problems-in-a-whirlpool-kenmore-direct-drive-washer/#ixzz3XW7eZwiN
By the way my advice is free cuz God is good!
Diagnosing and Repairing Spin and Agitate Problems in Whirlpool Kenmore...
Whirlpool... | Answered on Mar 24, 2017
You'll have to be a little more specific please. What kind of trap are you thinking of/referring to? Not aware of any type of "trap " on this model. Are you talking about some sort of lint trap? And what problem/s are you having with the washer (like what's it doing or not doing)?
Whirlpool... | Answered on Jul 29, 2016
probably a problem wash engage solenoid underneath or broken drive belt
call an technician in for a proper diagnosis and a quote
Whirlpool... | Answered on Jul 16, 2016
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
2,460 questions posted
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
View Most Popular
  • Whirlpool Washing Machines
Most Popular Question
water overflowing wont stop even when
  • Washing Machines
