20 Most Recent
Kenmore 24032\24036 Top Load Washer Questions & Answers
Agitate/Spin Issues (again)
if your coupler is good change your agitator dogs that will fix slow wash and clutch on top of transmission or lid switch for no spin
12/25/2023 3:57:56 PM •
Kenmore...
Answered
on Dec 25, 2023
Washer fills slow only in the rinse cycle
I had the same problem with my Kenmore Model 11022956102 washer and first thought that it was the water inlet valves. So I replaced them, but found the problem continued. After about 25 seconds into the rinse cycle the water only trickled in. Checking with a voltage meter I found that I lost 120V at terminals 3 & 5 on the washer temperature controller after 25 seconds. Even though the wiring diagram doesn't show the water temperature control board, since it's full of resisters and capacitors, I figured it was the most likely problem. So I ordered a remanufactured board from Parts Simple (#3407125), received and installed it. The 17 year old washer is now working fine once again. I hope this helps someone with the same problem. /s/ Paul
8/23/2022 11:24:48 AM •
Kenmore...
Answered
on Aug 23, 2022
Baby clothes under the ringer
Loosening top plastic nut and removed top 1/2 of agitator, then loosened nut to lift out bottom 1/2 of agitator.
6/27/2019 3:47:39 PM •
Kenmore...
Answered
on Jun 27, 2019
Dont drain
Hi
This issue usually occurs due to kinked drain pipe, clogged
drain filter or drain pump. First make sure that the drain is not clogged and
remove clogs if present. If no visible lint is present then remove the lower
front access panel to check the drain filter and drain pump for any clogs,
you'll need to clean the drain filter and drain pump completely. Hope this
helps... Please post back for any further assistance.
Daniel
11/9/2018 8:29:08 PM •
Kenmore...
Answered
on Nov 09, 2018
Indesit washing machine
? 3:34
www.youtube.com/watch?v=-lnfePzPwTQ
Jul 29, 2012 - Uploaded by porracaralho caralho
Indesit Washing Machine lWB5113 Flashing Lights(Faulty).mp4 .... older model- stopped in rinse cycle/flashing power and rapid wash lights- ...
? 0:43
www.youtube.com/watch?v=Q9Yq2Cz8UFE
Jun 26, 2011 - Uploaded by XR600RQJ
Washing machine Indesit starts to flash for longer and longer ...How do you unlock the door when the power is off?? every time i turn it ... My washing maschine ( Indesit WITXL 129 ) had the same problem - 6 from 9 LED lights ..
9/7/2018 3:06:24 PM •
Kenmore...
Answered
on Sep 07, 2018
Washer fills, but not agitating or draining
If the lid switch is faulty, or incorrectly adjusted, the drive motor is prevented from running. You do not say whether your repair man replaced the switch or the mechanism, but draining and spinning will only happen when the lid switch is engaged.
3/2/2018 6:06:26 PM •
Kenmore...
Answered
on Mar 02, 2018
My kenmore washer model 110.27802690
Under the lid there should be a small hole with a push down flap and that should be the automatic stop, which can either be a bad switch under the top of the machine or could be a broken trip/ prong on the lid that pushes this button when the lid is dropped. When the machine reaches it's spin cycle time leave it turned on and raise the lid push down on this flap with something careful to keep hands out of the washers tub and see if it works then!
3/2/2018 5:50:59 PM •
Kenmore...
Answered
on Mar 02, 2018
