Sewing Machines Logo
s
sally Posted on Jul 20, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What needles do I need gor brother db2b7353 - Brother Sewing Machines
Ruth summersides
Level 3:
Genius:
  • Brother Master 1,493 Answers
  • Posted on Nov 30, 2021
Ruth summersides
Brother Master
Level 3:
Genius:
Answers
1493
Questions
Helped
363464
Points
2425
Any sewing machine needles with a flat back can be used according to the material you are sewing.
Brother XL4011 sewing machine needle hitting plate
http://download.brother.com/welcome/doch000293/xl21202220om01en.pdf
Sometimes that happens when I have the needle position wrong. If that isn't it, you might need to take it for a repair.
1helpful
What size needle do I need for a brother db2 755 mk3?
Contact your local Brother dealer. They carry the needles you need for your machine. The needles should all be the same length for your machine. If you continue to have issues with your machine, be sure that you ALWAYS RAISE the presser foot when threading the top thread. If there are still more problems, you may have knocked the machine out of time when it broke the needle.
Owners do I procure needles for brother 523n Overlocker please
Your manual should tell you what needles to purchase for your machine. Search for "Brother 523n needles" and see what comes up. Your local Brother dealer will have needles for your machine.
I need an automatic needle threader for a Brother NS30 Le
You might check out these sites for repair ideas:
Brother NS30 LE needle threader Google Search
otherwise you will need to contact Brother or a sewing repair supply for a replacement part
How do I change a needle on a brother 770?
Here is what I found Hope it helps. I didn't download anything, I just clicked on the pages and scrolled down. Here is the contents page
http://homeappliance.manualsonline.com/manuals/mfg/brother/cs770.html?p=5
Here is the page you need:
http://homeappliance.manualsonline.com/manuals/mfg/brother/cs770.html?p=23
21
Checking the needle
Sewing with a bent needle is extremely dangerous since the needle may break while the machine is being operated.
Before using the needle, place the flat side of the needle on a flat surface and check that the distance between the needle and the flat surface is even.
aFlat side
bNeedle type marking
?Correct needle
aFlat surface
?Incorrect needle
If the distance between the needle and the flat surface is not even, the needle is bent. Do not use a bent needle.
aFlat surface
Replacing the needle
Replace the needle as described below. Use the screwdriver and a needle that has been determined to be straight according to the instructions in "Checking the needle" .
a
Raise the needle by turning the handwheel toward you (counterclockwise) so that the mark on the wheel points up. (With models equipped with (needle position button), raise the needle by pressing once or twice.)
b
Turn off the sewing machine.
c
Lower the presser foot lever.
aPresser foot lever
Needle keeps breaking HELP!
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time
I suggest contact brother.com or a dealer about the needles , cause
I've checked on the internet and on the brother site about the needles and couldn't find any information.
2helpful
I need new needles and bobbins how do I find right ones
You can use Schmetz needles and the bobbins are Class A or Class 15. Both can be found where sewing notions are sold.
You choose the needle size according to the type of fabric you are sewing. This should be in the manual.
If you need a manual, you can download from the Brother website.
10helpful
2answers
Brother VX-1120- The needle is not picking up bobbin thread.
I had the same problem with my brother vx-1120 sewing machine. I set the needle to lowest position by using the hand crank. Then I loosened the knerled set screw that holds needle in place. Then I moved needle shaft till the eye of needle is just lower than the hook on the shuttle loop maker. It made my mechine work. There are instuctions for ajusting timing on machine but I think these mechines are built to not fix and throw out. Just because there where no ajustment marks at all on machine, any machanical machine will needed to be ajusted sometime.
Top Brother Sewing Machines Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
