20 Most Recent
Brother XL-3500 Questions & Answers
HELP!!! I was sewing and heard a 'SNAP'
no make . model or other details given so a correct answer is out of the question
it indicates that the drive belt from the top shaft to the bottom shaft has broken
take it in for a proper diagnosis
Feed Dog is not working?
Not sure if this model has a Feed Dog switch. May be located in area covered by storage portion of sewing bed. May be located on back side of freearm area will be indicated by multiple triangles near the switch.
Cheers,
Kelly
San Diego, CA
Embroidery Services
What number of size needle is xl 3500
Hello Veronica, The needle system for your machine is 130/705H or 130/705HB also recognised as a 15x1. This is a very common system for most all home machines. The needle measures 1 17/32 inches long , and has a flat side on the shank. There are nine different thicknesses of needles in this system ranging from 60/8 being the thinnest to 112/19 being the thickest. 90/14 is the most popular. I prefer 110/18 for the repair of jeans. The smaller the number, the smaller the eye of the needle. The larger the number, the larger the eye of the needle. The thickness of material you want to sew and the thickness of thread you want to use will determine what size needle you should use .
