20 Most Recent Brother LS-1217 Mechanical Sewing Machine Questions & Answers
2answers
Where do i oil it
Check your owners manual under "Maintenance" it should tell you and even illustrate the points that should be oiled regularly. Have a great day!!!
11/19/2021 11:04:24 AM • Brother LS-1217... • Answered on Nov 19, 2021
2answers
Spring unattached on Brother LS-1217 near bobbin
Check out this site. There is pictures of each machine there. All the Q&A answers in simple language, as well as a GREAT cust. support. (its a Brother after all!)
I found download manuals there as well.
http://welcome.solutions.brother.com/bsc/public/Model_list.aspx?reg=us&c=us&lang=en&titleid=36
I hope this helps! Thanks for keeping the Art of sewing going!!!!
Happy sewing!
3/3/2020 11:55:19 PM • Brother LS-1217... • Answered on Mar 03, 2020
3answers
I have a Brother LS-1217. The tension will not
You should be able to fix this. IF it is the top thread on your fabric that is screwy you need to adjust the bobbin tension.
If it is the bottom thread you have a problem with your upper tension. Blow out the upper tension assembly using canned air, the tension discs may be dirty
8/10/2018 9:21:35 PM • Brother LS-1217... • Answered on Aug 10, 2018
I have a bush 24 stitch machine for xmas, just a
Ok, since you said a needle broke, that is a good indication of where to look. You obviously already installed a brand new needle (which is the first thing to do). Verify that you have installed the needle facing the correct direction--there is usually a flat surface on the needle that needs to face a particular direction in the machine. Remove the bobbin from the machine and rethread it and install it correctly in the machine. If you've done all of this and the machine still will not pick up the bobbin thread, the bad news is that the broken needle may have knocked the machine out of time. Sorry, that happens a lot with broken needles. You will probably need to take it for service as the needle and hook timing are out of sync.
2/25/2018 4:41:31 PM • Brother LS-1217... • Answered on Feb 25, 2018
2answers
My upper thread keeps on
12/8/2017 6:44:47 PM • Brother LS-1217... • Answered on Dec 08, 2017
2answers
Bobbin thread won't come up with top thread .
hi there. this is all i could find.go to this link and see if it helps you out. Bobbin thread won come up with top thread Google Search
11/18/2017 5:20:12 PM • Brother LS-1217... • Answered on Nov 18, 2017
The problem actually started with
Re thread the machine, and make sure the bobbin is installed correctly. Cheers, Chance Embroidery Services San Diego, CA
5/4/2017 11:01:50 PM • Brother LS-1217... • Answered on May 04, 2017
I need the scymmatics to my sewing machine Brother LS-1217 the bobbin area I need to know where to connect the springs behind thd bobbin
I would try here Support Center it is the brothers site for : Find official Brother LS1217 FAQs, videos, manuals, drivers and downloads here. Get the answers and technical support you are looking for. The information is not in the regular manual you need the tec manual that the repairmen learn from I hope this helps
4/21/2017 2:18:23 AM • Brother LS-1217... • Answered on Apr 21, 2017
I need a manual for brother la 1217 sewing machine
Try here. https://www.manualslib.com/manual/219352/Brother-Ls-1217.html
1/2/2017 7:26:04 PM • Brother LS-1217... • Answered on Jan 02, 2017
0answers
Need to find replacement Brother
This site is selling a replacement table, took forever to find the part number XA9975021 Extension Table Brother XA9975021
9/8/2016 1:42:32 AM • Brother LS-1217... • Answered on Sep 08, 2016
3answers
Why wont my brother sewing machine sew straight
make sure the zig zag stitch is in the O position
8/17/2015 9:22:49 PM • Brother LS-1217... • Answered on Aug 17, 2015
How do I lower the feed dogs?
Look for a dial or switch under your machine, it may be difficult to move! Good luck!
7/11/2015 8:41:08 PM • Brother LS-1217... • Answered on Jul 11, 2015
2answers
Thread Breaks
Dear Sir / Madam, please get your book out and follow the threading instructions very carefully. I am certain that is your only problem.
Kindest Regards,
Cookey.
7/9/2015 8:32:59 PM • Brother LS-1217... • Answered on Jul 09, 2015
Brother LS-1217 Mechanical Sewing Machine Logo
271 questions posted
Top Brother Sewing Machines Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Brother Sewing Machines
Most Popular Question
when start sewing sometimes material
  • Sewing Machines
