20 Most Recent
Brother CS-8150 Computerized Sewing Machine Questions & Answers
Brother VX-1120- The needle is not picking up bobbin thread.
I had the same problem with my brother vx-1120 sewing machine. I set the needle to lowest position by using the hand crank. Then I loosened the knerled set screw that holds needle in place. Then I moved needle shaft till the eye of needle is just lower than the hook on the shuttle loop maker. It made my mechine work. There are instuctions for ajusting timing on machine but I think these mechines are built to not fix and throw out. Just because there where no ajustment marks at all on machine, any machanical machine will needed to be ajusted sometime.
Bobbin winder shaft wont spin
I opened up my machine to find that the bobbin winder wheel (little black ring) had totally turned into black sludge in my machine. It is very gooey and hard to remove. I ordered the part from sewingpartsonline.com and replaced the ring. It is still not working..... ugh
Fixing the digital screen
If it is in fact the circuit board, you will probably need to have it serviced unless you know someone who is a computer repair guru.If you just purchased it new, it is still covered under warranty....
How do I disassemble my
If you or someone you know is
mechanically inclined, you will need to take five screws out of the
back including a hard to find one under the foot raising lever (lower
the foot), then one form the front that is under the thread cartridge,
and you will have to remove the bobbin winding plate cover which is
held by one small screw, and then remove a small screw from the support
bar.
L2525 tension
Which tension? If it's the upper tension (loops on the bottom of the fabric), rethread the top from scratch, this time with the presser foot UP so the thread can enter between the tension disks. Presser foot down to sew, which engages the tension.
Not sewing
Suggest open bobbin case to see if loose thread has jammed it.
