20 Most Recent Brother PE-150V Computerized Sewing Machine Questions & Answers
The top thread is being
top thread tension is not tight enough the tension is correct when you feel resistance as you pull the thread to put it through the eye of the needle
11/6/2017 11:11:00 PM • Brother PE-150V... • Answered on Nov 06, 2017
0answers
0answers
2answers
Pe-150 embroidery power cord
Two places you can check. The first is Ron at a1sewingmachine.com or Wendy at [email protected].
3/29/2014 7:57:14 PM • Brother PE-150V... • Answered on Mar 29, 2014
Brothers pe150 embroidery machine will not sew
If you tighten up your needle thread, reduce the tension of the needle thread.
For embroidery, and zig-zag, and because the needle makes side movements, it needs more needle thread.
So try to keep you needle thread not very tight,
and tight up your bobbin case tension more, so that the two threads meet under the meterial.
9/15/2013 2:43:01 AM • Brother PE-150V... • Answered on Sep 15, 2013
A high pitched sound comes out of machine when inserting card.
I'm new to embroidering and mine did the same thing a few weeks ago. I discovered the buzzing sound was because the design I saved to the card was too large. I decreased the size and the design worked perfectly.
7/22/2013 11:21:54 PM • Brother PE-150V... • Answered on Jul 22, 2013
Bottom thread not picking up!!
try turning the bobbin the opposite direction and if that doesn'thelp the it would be a good idea to have the machine serviced..
5/16/2013 2:44:50 PM • Brother PE-150V... • Answered on May 16, 2013
Brother PE-150 cannot read PED card
there could be something wrong with the card or the card readercould be going out.you might check with brother and see if there is up date for the machinethat you can download.also if the problem persists, the machine may need to be checked
12/14/2012 2:40:53 PM • Brother PE-150V... • Answered on Dec 14, 2012
My needle keeps breaking
Needle breaks 1.the needle is damaged 2.the needle is not correctly inserted 3.wrong size needle for the fabric 4.the wrong foot is attached 5.the needle clamp screw is loose 6. Top tension is too tight 7. Machine could be out of time
12/3/2012 8:27:31 PM • Brother PE-150V... • Answered on Dec 03, 2012
Needle keeps breaking HELP!
Needle breaks 1.the needle is damaged 2.the needle is not correctly inserted 3.wrong size needle for the fabric 4.the wrong foot is attached 5.the needle clamp screw is loose 6. Top tension is too tight 7. Machine could be out of timeI suggest contact brother.com or a dealer about the needles , causeI've checked on the internet and on the brother site about the needles and couldn't find any information.
12/3/2012 8:25:55 PM • Brother PE-150V... • Answered on Dec 03, 2012
Needle goes down but don't pick up the bobbin thread. It come up and tell me that my upper or lower thread is cut.
try changing the needletry rethreading the machine top and bobbinmake sure to use every thread guide-this is improtant for the thread tensionmake sure the bobbin is turned correctly in the bobbin casealso could be a problem with the computer motherboardor there could be a problem with the timing
12/3/2012 8:07:19 PM • Brother PE-150V... • Answered on Dec 03, 2012
Brocken belt
Take it in, the belt is inside along with elelctronic components that are seriously deadly to those inexperienced with electronics. Also machines with inside belts are very easy to knock out of timing. So spend the $$ and have it replaced and the machine serviced and adjusted while you are there.
10/5/2012 4:05:52 PM • Brother PE-150V... • Answered on Oct 05, 2012
How do you change the timing on brother pe150 as it wont pick up bottom thread
Full details on how to adjust the timing appear here in my Brother PE150 blog. You will need a few basic tools including the stubby screwdriver that came with your machine.
3/20/2012 10:32:48 PM • Brother PE-150V... • Answered on Mar 20, 2012
3answers
Set the timing
take off the bottom cover by removing 4 20 trox screws and 2 or 4 small phillips screws, the bottom part of the hook has two allen screws on it that can come loose causing you to lose timing, lower the needle all the way and then raise it a little bit putting the tip of the hook just above the eye of the needle and then tighten the allen screws and add some lock tight
1/1/2012 3:23:40 PM • Brother PE-150V... • Answered on Jan 01, 2012
2answers
Time janome 3018?
when you say 'bobbin thread bunches' i take it that when you look at the underside of what you have sewn it looks messy. if this is the case and the machine is threaded correctly and the the needle thread is tight enough to bend the needle a little when pulled (with presser foot down) it will most likely be that you need to increase needle tension (maybe to max) when sewing thick fabrics with thicker than normal thread.
if the the needle does not bend a little you may not have the thread in between the tension discs, or there may be thread or lint caught in the tension discs preventing proper tension (try pulling a thin rag through the tension discs to dis-lodge any foreign matter).
scott.
10/18/2011 5:58:11 AM • Brother PE-150V... • Answered on Oct 18, 2011
Brother PE-150V Computerized Sewing Machine Logo
96 questions posted
Top Brother Sewing Machines Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Brother Sewing Machines
Most Popular Question
brocken belt
  • Sewing Machines
