20 Most Recent
Brother PE-770 Embroidery Machine Questions & Answers
Brother 780D will not feed thread through machine.
It is very important to have the bobbin case and the top tension both right. If the thread is getting stuck there is a problem. Always thread the top with the foot up. While threading make small pulls to make sure there isn't any places getting jammed. I've attached a rule document to help you to adjust the tension of the top and bottom.
How do I change a needle on a brother 770?
Here is what I found Hope it helps. I didn't download anything, I just clicked on the pages and scrolled down. Here is the contents page
http://homeappliance.manualsonline.com/manuals/mfg/brother/cs770.html?p=5
Here is the page you need:
http://homeappliance.manualsonline.com/manuals/mfg/brother/cs770.html?p=23
21
Checking the needle
Sewing with a bent needle is extremely dangerous since the needle may break while the machine is being operated.
Before using the needle, place the flat side of the needle on a flat surface and check that the distance between the needle and the flat surface is even.
aFlat side
bNeedle type marking
?Correct needle
aFlat surface
?Incorrect needle
If the distance between the needle and the flat surface is not even, the needle is bent. Do not use a bent needle.
aFlat surface
Replacing the needle
Replace the needle as described below. Use the screwdriver and a needle that has been determined to be straight according to the instructions in "Checking the needle" .
a
Raise the needle by turning the handwheel toward you (counterclockwise) so that the mark on the wheel points up. (With models equipped with (needle position button), raise the needle by pressing once or twice.)
b
Turn off the sewing machine.
c
Lower the presser foot lever.
aPresser foot lever
Troubleshooting Brother PE 770
Usually this is a tension problem. On mechanical machines, you'd adjust the dial, or possibly even the bobbin tension. But on a computer machine, I don't know how you set the upper tension, sorry to say.
Sometimes it can help to unthread and rethread a machine, and I don't know why it sometimes works, but it's a simple thing to try.
But if the upper tension isn't set correctly for the work being done or if the tension mechanism, however that's handled on a computer machine, isn't working correctly, this is what happens. Bird's nest is a good way to describe it.
Sometimes lint built up in the bobbin case can cause this symptom too, but I'd assume you keep this area clean. One reason I haven't yet invested in a computer machine is because problems like this often don't have such simple solutions as on the mechanical machines.
