Ravi Gupta Posted on Apr 20, 2019
Ir2230 e003 - Office Equipment & Supplies
1helpful
2answers
E003 Error code in canon ir2420 photocopier
Code E003-0000 Description Abnormally low temperature (detected by main thermistor)
After the temperature detected by the main thermistor has reached the specified value, it does not reach the specified value during initial rotation. Remedy - Check the connector of the fixing film unit. - Replace the fixing film unit. - Replace the DC controller PCB. Error Codes Canon iR2420 Code E003 0000
Where are fixed toner sensor in iR2230 machine, give me image or video
Open the front door and side door and pull out the developing unit. Just under the it is the toner sensor unit.
E003 Switch the power on and off again
check if thermistors are ok/or replace them
If the fixing heater fails to operate.
• E002 or E003 is indicated.
5helpful
File error - in NW-E003 SONY MP3 WALKMAN
I get no data file error when i try to play the song in my NW-E003 SONY MP3 WALKMAN player
I AM ATTEMPTING TO USE THE SCANNER FUNCTION ON A CANON IR2230
Firstly, the machine must be connected to a pc or network. Secondly, you must scan the document to a pc so, after you have switched on, as you have, the scanner so that it says 'online' you will need to go to the pc and 'PULL' the document to the pc from the scanner. However, to do this you will need to have installed NETWORK SCAN GEAR on your PC inorder to SCAN. When you install the software, you will need to DISCOVER the scanner before it will be ready for use. So, a recap:
1. You NEED a program called NETWORK SCAN GEAR on your PC
2 Your ir2230 must be connected to a PC or network
3 You need to DISCOVER your ir2230 from your PC
4 You then need to INSERT picture FROM SCANNER and select your ir2230 from within a program such as WORD using NETWORK SCAN GEAR
Good luck
2answers
I have a problem with copier GP 225 it gives E003 how do I clear this code?
fuser temp not rising at correct pace. could be thermistor,thermal switch or fuser lamp
2answers
Canon NP-6612 copier Signal E003
E003 is fixing low temp error
please check thermistor and heater
k24674
ADMIN Andrew
ADMIN Andrew
