20 Most Recent Sharp AL 1631 Copier Questions & Answers
if the scanner is not locked, you can try pressing #*C* then enter 14 and press start, if it is not resolving your problem you need to replace the carriage motor mcu pwb and the power supply pwb respectively.
Sharp AL 1631... | Answered on Jan 13, 2018
If the round red light you describe is a circle of dots that indicates a developer change is due. This needs to be done by a technician but the machine should work fine without doing the developer change.
Sharp AL 1631... | Answered on Nov 17, 2017
The problem it in exposere lamp section.The forward scan is not compelet.Cause is the mirror motor control board or mechanical parts.
Sharp AL 1631... | Answered on May 11, 2017
replace the fuser and check for a blockage after the fuser
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Sharp AL 1631... | Answered on Mar 13, 2016
I have a tip posted for this problem.
You can view it here:
http://www.fixya.com/support/r4378514-sharp_al_series_copier_l1_l_1_error_code
Good luck and thank you for using Fixya
Sharp AL 1631... | Answered on May 28, 2015
I have a tip posted here at Fixya that covers the Sharp AL Series Copier L1 code.
Here is the link:
If it helps you with your L1 code then please return here and provide some feedback.
Thanks,
WheatlandServices
Sharp AL 1631... | Answered on Mar 27, 2015
L1 or L1-00 indicates Scanner movement failure. The scanner is the part under the glass that lights up and moves back and forth. So if you lift up the feeder so you can see the glass, turn the machine off for a few seconds then back on. Watch the movement of the scanner. It should move right and inch or two then back to the left. If all goes well the copier should come to ready. Lay a piece of paper on the glass and press the print button to watch the scanner movement. If it binds up or does not scan correctly there are 2 possibilities.
1) your scanner lock is engaged and is preventing the scanner from moving. Check the clear plastic dial located under the far left upper side of the copier, near where the paper exits the machine. Make sure it is in the unlocked position.
2) Your scanner rail is dirty and dry. This rail can be seen under the glass towards the back of the copier. The scanner rides on this rail. It is very common for these to get dirty and for the grease to dry up causing the scanner to freeze up on the rail. The glass must be removed and the rail cleaned and lubricated.
Just power off then on the copier to reset.
Sharp AL 1631... | Answered on Jan 22, 2015
If your copier front or right cove is not attached properly then CH on standby, or CH is blinking/flashing may be your copier TD unite is not adjust or close.
Sharp AL 1631... | Answered on Oct 29, 2014
Copies come out with one black line
Sharp AL 1631... | Answered on Aug 26, 2014
Welcome to Fixya
Try to reset the copier. Enter buttons clear, exposure, clear, exposure, the display will blank, enter 14, press print button, then clear several times to get out. This will reset the machine. Would ib be possible also if you can provide me the number showing on the screen.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Sharp AL 1631... | Answered on Aug 05, 2014
the problem is with the fuser.
check the lamp and see if it is not burned
the other problem can also be the thermofuse: it is a fuse to prevent the fuser from getting too hot
Sharp AL 1631... | Answered on Jul 21, 2014
problem on scanner motor
Sharp AL 1631... | Answered on Jul 17, 2014
I have a tip posted here on Fixya that resolves this problem easily.
Here is the link:
http://www.fixya.com/support/r4376849-sharp_al_series_copier_h3_h_3_code_reset
If it works for you then please return here and provide feedback for me that I was helpful.
Thanks
Sharp AL 1631... | Answered on Jul 14, 2014
should be Hand then 4
Sharp AL 1631... | Answered on Jun 27, 2014
please press C photo C photo than press up and down key 16 press print key restart your copier may be fix
Sharp AL 1631... | Answered on Jun 16, 2014
Hi, you can stop a copy half way to see if it image is on the on the drum if not check and make sure toner unit is turning. if not main charge. thanks dale.
Sharp AL 1631... | Answered on May 08, 2014
Sharp AL 1631 Copier Logo
682 questions posted
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
George Mclaughlin
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Office Equipment & Supplies
Most Popular Question
replace drum unite
  • Office Equipment & Supplies
