20 Most Recent Epson WorkForce WF-4630 Wireless Color All-in-One Inkjet Printer Questions & Answers
11answers
On an Epson WF-4630, what does error code 0x97 mean and how do I correct it?
I am on my second printer with the error. Epson explained it is a motherboard failure. The error is not caused by a PC or the software on it. Instead, this is a printer hardware failure. After exchanging the printer, the replacement printer has now dies from the same error. The problem starts as blurry printing and progresses to the full hardware failure. Once the Hardware fails and you get the error code, there is nothing an end user can do. The motherboard needs to be replaced. My printers were working fine up until I swapped out the factory cartridges that shipped with the printer. In both of my cases, there were no issues or symptoms until I started using the Epson XL cartridges. As soon as I installed those, the symptoms started to show. Within a couple of months after swapping in the XL cartridges, the motherboard dies. Options: 1) Call Epson and complain, make them log the details even if it is out of warranty. This helps establish the pattern and knowledge of the issue. 2) Swap printer if under warranty. They may want a credit card to charge in case they do not receive the bad printer back. Just resend it in the box the replacement came in. Epson supplies shipping labels and covers the shipping costs.
11/6/2021 5:36:17 PM • Epson WorkForce... • Answered on Nov 06, 2021
Ho do you reset the ink levels on an Epson WF-4630 (T7861)?
Ink levels are set by chips on the ink carts. You may be able to reset the chips with a "chip resetter", but that's not really recommended. Get refillable carts with automatic resetting chips...
3/1/2021 11:38:50 AM • Epson WorkForce... • Answered on Mar 01, 2021
2answers
Epson Wf-4630 keeps jamming when i use the ADF to scan documents
You may need to clean the rubber rollers. I have attached videos on how to do so. How to clean ADF Rollers: Clear Epson ADF Error:
3/1/2021 11:38:26 AM • Epson WorkForce... • Answered on Mar 01, 2021
Error 0x97 fix for Epson 4630 printer
if you face any issue while using printer then visit here : http://toshiba.hpsupportnumbers.com/toshiba-printer-customer-care
6/17/2019 7:25:31 AM • Epson WorkForce... • Answered on Jun 17, 2019
MY EPSON WF-4630 PRINTER IS STUCK ON oxf4 AND WE CAN'T CLEAR IT. WHAT DO WE DO??
If you are lucky, the 0xF4 error indicates a foreign object (a scrap of paper) in the gears. That would translate to PF driver mechanism overload. Another cause would be a contaminated encoder scale. Fixing either of these will require you to disassemble the printer. Here are some tips for taking apart the printer: https://www.ifixit.com/Guide/Repairing+EPSON+B-510DN+Error+0xF2+or+0xF3/11767 . However, the 0xF4 error could mean that the encoder board or the motor have failed. These errors can only be fixed by a service technician. If your printer is under warranty, you should call for service. Otherwise decide if you want to risk taking it apart and finding that you can't fix this error. It may be cheaper to replace the unit. I hope this helps. Cindy Wells
6/20/2016 10:05:44 PM • Epson WorkForce... • Answered on Jun 20, 2016
PRINTING ERROR MESSAGE?
If you wish to get some details; check the site linked here. Pull up older posts..... http://electro-medical.blogspot.com/
6/20/2016 4:27:30 PM • Epson WorkForce... • Answered on Jun 20, 2016
How can I reset the density level?
Two places to check and make changes. One is on the printer menu itself. Hit menu and navigate to print options. The second will be on your computer. When you go to print something a menu will pop up for a printer selection. It will also have an advanced button. Hit that and it will get you into an area to change the printing in multiple ways.
2/10/2016 1:17:55 AM • Epson WorkForce... • Answered on Feb 10, 2016
0answers
3answers
Epson wf-2530 printer error see your documentation
Turn the printer unit ON 2. Pull the power plug from the back side of it 3. wait 1 min 4. Plug unit back in 5. wait 3 full minutes 6. try to print does the error still exist? If yes continue below Locate one piece of CARD STOCK paper and manually feed it up against the feed assembly and into the feed.Must be CARD STOCK PAPER, regular paper will not work. the idea is too dislodge any pieces of paper that may be broken off inside the rollers, and not visible to the eye. Repeat this process until the error goes away. If you continue to experience problems, PLEASE RESPOND TO ME
2/26/2024 2:28:21 PM • Epson WorkForce... • Answered on Feb 26, 2024
How can I replace waste pad of WF 1100, where it located?
When printer's ink pads full then you need to be changed. Do you know what is waste ink pads? In the printing process, the printer produces waste ink that has to go somewhere and it send through a tube to ink pad where it is collected. Don't worry! You can easily reset/replace the water ink pad: Step1: Remove viewing panel on the back of your printer's right side. Some other printers it will be rectangular panel, and on others it will be right side of the printer. Use a Philips head, or screw driver to remove it. Step2: Now you can find the ink waste tubes. It is easy to locate because they will be two clear tubes running side by side into the ink waste reservoir. Some printers will only have one tube. One end of the tubes will be attached inside the printer and the other ends will be loose. Pull the loose ends of the tubes through the panel opening. You may need to use needle nose pliers to accomplish this if you cannot easily grasp the tubes with your fingers. Step3: After that remove the old pad. Wear rubber gloves when you remove it. Using the pliers, pull the pad out of the printer and set it aside. Clean out the reservoir by pushing paper towels into it and letting them soak up the ink. Step4: Now you can replace the pad. You may also try cleaning the old pad by letting it soak in a large bowl of hot water then squeezing it out. Make sure it is completely dry before putting it back in the printer. I hope you these steps to help you replace the waste ink pads. If you need any help, then contact Epson printer experts through Free live chat. They surely help you to fix the issue.
9/13/2022 6:28:29 AM • Epson WorkForce... • Answered on Sep 13, 2022
Epson workforce wf-7710 error code 000025
Yes
10/17/2021 6:06:59 PM • Epson WorkForce... • Answered on Oct 17, 2021
Printing avery labels on epson workforce 630
My Epson XP-7100 would not print Avery labels no matter what settings I used for the paper, weight, format in the printer properties. So I used the PRINT function in Word and did "Microsoft Print to PDF". Then I used the resulting pdf and printed it onto the label sheet in my Epson XP-7100. Worked great. Does seem that if Epson printers can't print using the label file in Word, that at least Epson would put a work-around solution on their website. I had to figure this one out on my own. Although it is easy and relatively quick to do, I took a lot of time to come up with a way to print my Avery labels. Epson, get on the ball!
9/27/2021 12:34:00 PM • Epson WorkForce... • Answered on Sep 27, 2021
Epson wf7710 making terrible sound when printing
Might pape is stuck, run a clean up.
2/22/2021 3:17:28 PM • Epson WorkForce... • Answered on Feb 22, 2021
Epson WF 7610 has a error message ERROR Code 0x9E
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/
2/24/2019 12:45:19 AM • Epson WorkForce... • Answered on Feb 24, 2019
Reset ink levels on epson workhorse 645
The process is quite easy, here is a short tutorial on it: Solved How To Reset Epson Ink Cartridges
9/10/2018 8:04:30 AM • Epson WorkForce... • Answered on Sep 10, 2018
Epson WorkForce WF-4630 Wireless Color All-in-One Inkjet Printer Logo
11 questions posted
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
WorkForce Epson
  • WorkForce Epson
Most Popular Question
printer not reacting print mean when
  • Office Equipment & Supplies
