20 Most Recent Ricoh Aficio SP C320DN Color Laser Printer Questions & Answers
Google search suggests either replace cartridges, or change firewall settings.
Ricoh Office... | Answered 2 days ago
i have a richo sp 210 su printer but start time service call 542 error i help
Ricoh Office... | Answered on Jul 13, 2019
SC491 on a Ricoh SP 210SU is a code for bias leak.
The machine detects that a bias leak has occured from the drum charge, development charge or transfer charge.
PWM signals are sampled at 20 msec. intervals. This SC is issued if 10 PWM samplings within 200 msec. are abnormal.
• HVPS (high voltage power supply) harness loose, broken, defective
• HVPS board defective
• AIO terminal defective (the terminal for the toner cartridge)
• Cycle the machine off/on
• Check all the harness connections of the HVPS
• Check spring-loaded AIO terminal installation behind the HVPS.
• Replace HVPS.
Usually this error is related to the cartridge. Some manufacturers of compatible cartridges will replace the cartridge with a new one.
At least they should give a discount based on how many pages that was printed before it failed.
I have not seen this problem with a new genuine Ricoh cartridge.
It is important that the cartridge is not refilled more then 3 times. There is no counter on this, and companies that refill cartridges they collect (with unknown number of cartridges) may have problems quite often.
Ricoh Office... | Answered on Jul 12, 2019
Your computer is not connected to your home network, your printer is not connected to your home network. That is the way they communicate.
Ricoh Office... | Answered on Jul 11, 2019
SC553 means an overheat error on the pressure roller, but this RTB corrects this to an overheat error on the heating roller. As a solution the heating roller thermistor should be replaced or the connections of this thermistor are faulty.
Ricoh Office... | Answered on Jul 06, 2019
I have a RICOH 210 just newly buied
Printer's both the Red continuously on while starting the Printer can any one help me out to get rid this problem.
Ricoh Office... | Answered on Jul 04, 2019
Ricoh Aficio SP C320DN Color Laser Printer Logo
4 questions posted
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Ricoh Office Equipment & Supplies
Most Popular Question
spc440dn not print service mode 1103
  • Office Equipment & Supplies
