20 Most Recent
Canon IMAGERUNNER 2230 Copier Questions & Answers
IR-2570CI
This error indicates that the patch image read sensor is dirty. You can locate the patch sensor by removing the drum unit from the front of the machine. The patch sensor is located in the machine, directly above the drum unit, halfway intothe machine. If you look into the machine and up you will see a white plastic unit running along the top about halfway point between the front and back of the machine. The patch sensor is inset into that unit and is black plastic. Clean with a lint free cloth several times - as it is hard to see the actual sensor, feel along the strip with your fingers until you can feel the indent where the sensor is - concentrate your cleaning around that area. Now replace the drum and turn the machine back on (I hope you turned it off first).
Removing the drum is easy but hard to explain. In fact, if you get the front cover off, you've done the hardest part. There are some hidden screws, one above the front cover to the left - as if you are looking down on the machine, there may be a small circular plastic cover hidding access to this screw. Remove it and unscrew. If you have an internal finisher, you will have to remove the circular covers above and below the front of it to push your driver through to the hole you need. Sounds complicated but once you've done it you'll see that it's easy when you know where the holes are. There is then another screw at the top, near to right that you access through the panel above - just look around and above the front cover to find the screws. Good luck
4/10/2016 3:20:08 PM •
Canon...
Answered
on Apr 10, 2016
My canon image runner 2230
try this solution: enter service mode by pressing *(additional function) then2 and 8 together and then again * select copier on screen>function>clear>error>ok. turn off the machine and re-start.
12/17/2015 5:45:31 AM •
Canon...
Answered
on Dec 17, 2015
We have a Canon iR
if e000024-0001 is comming plz clean the toner box in which magnet roll is runing then try you machine is not give this e000024-0001 singnal.
3/25/2015 3:29:52 PM •
Canon...
Answered
on Mar 25, 2015
Cant access the canon image runner IR2520 error E000001
Reset the error. Press "Additional Function" then 2 then 8 then "Additional Function". Go to #CLEAR > #ENGINER > #ERRCLR.
I recommend using AVR 2000W Servo type to your machine if error persist. It is due to supply fluctuations.
10/7/2014 8:59:02 AM •
Canon...
Answered
on Oct 07, 2014
Error E000805-0000
We do not have the explanation for that error code, I uspect you should first reinstall the software.
5/3/2014 6:38:06 PM •
Canon...
Answered
on May 03, 2014
