20 Most Recent Canon NP 6050 Copier Questions & Answers
E355 ir6020i
12/1/2018 11:10:39 AM • Canon NP 6050... • Answered on Dec 01, 2018
Canon NP6050 on off switch trips almost instantly. When the front door is open it stays on, but as soon as you close it and it starts warming up, it shuts itself off. What could the problem be?
it a open circuit in the back where the heater unit is.i had the same problem.check your pins that connect to the back it bent a little that what causes a open circuit.good luck
8/24/2018 8:30:16 PM • Canon NP 6050... • Answered on Aug 24, 2018
List of error codes in canon np 6050
eror203 is a lens motor gear
8/19/2018 11:41:01 PM • Canon NP 6050... • Answered on Aug 19, 2018
About my business...
Xerox DocuColor 3535 RC With Xp12 Feary Is the best for color & canon IR 6000 For Black & White
is Best For all.
6/26/2018 8:48:17 PM • Canon NP 6050... • Answered on Jun 26, 2018
4answers
E800
Hello
E800 means : E800 Auto power off circuit problem. Main switch or DC controller
10/3/2017 4:29:27 PM • Canon NP 6050... • Answered on Oct 03, 2017
2answers
NP6050 false paper jam at doc feeder
When you put documents in the feeder and you push start do you see 2 black arms swing out to count the number of orignals? If yes, dose the doc tray begin to go down and then jams? If yes, you can try something.... OK, turn the copier off and move the 2 paper guides of the doc tray toward the middle. You need a #2 philip's head screw driver. Remove the 2 silver screws that will be sunk in a bit on the top of the doc tray. Once you remove the screws, remove the top part of the doc tray and you will have one connector toward the front. Unplug it and replug it back in and see if that works, if so return the 2 screws and you should be OK.
8/31/2017 6:34:23 PM • Canon NP 6050... • Answered on Aug 31, 2017
Mesin np 6551 error 30
replace counter
3/15/2016 9:36:03 AM • Canon NP 6050... • Answered on Mar 15, 2016
What is E34 error?
web search canon error codes cursor through listings to find your error code and solution
9/4/2015 12:19:42 AM • Canon NP 6050... • Answered on Sep 04, 2015
Re insert unit 3 pada canon NP 6050
can u show me where motor and sensors
8/10/2015 4:12:05 AM • Canon NP 6050... • Answered on Aug 10, 2015
2answers
WE are purchasing one of these copiers today and I
Sorry Canon NP 6050 is not networkable. this copier is an analog copier or a plain copier only. if you want a networkable printer/copier you need a digital copier with printer option.
7/17/2015 11:51:49 AM • Canon NP 6050... • Answered on Jul 17, 2015
Np 6512
I did some research on my end about my repairs but came up empty. Sorry Owen
4/9/2015 6:24:21 AM • Canon NP 6050... • Answered on Apr 09, 2015
What does E005 mean?
Ir 405 copier code as displayed e005 but what is problem am changed web... Someone else already posted this, try the suggestion posted there.
3/15/2015 9:14:02 PM • Canon NP 6050... • Answered on Mar 15, 2015
How reset error code E005
You hawe to replac web on fixing unit.Than you must clear error in service mode
2/18/2015 7:23:03 AM • Canon NP 6050... • Answered on Feb 18, 2015
How can remove e203 problem and scanner not move fully .
Check the sensors and photointeruptors for scanner home position
9/30/2014 1:01:18 PM • Canon NP 6050... • Answered on Sep 30, 2014
6050 ERROR E006
That is a Fuser error, in particular a Fuser feed connector issue. you may need to replace the Fuser Rollers, Bushings and Bearings then go to the service menu and clear the error.
6/11/2014 8:14:39 AM • Canon NP 6050... • Answered on Jun 11, 2014
Canon NP 6050 Copier Logo
467 questions posted
old marine
old marine
ZJ Limited
ZJ Limited
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
6050 error e006
  • Office Equipment & Supplies
