Printer PRIXMA 4400
SOURCE: Check Printer (5B00)
try this -
1) Enter SERVICE MODE By pressing Menu-Scan-Copy-Scan
2) Enter NVRAM by presing <--- or ---> then OK
3) SET ABS-M LEVEL TO 0
4) OK
good luck
SOURCE: Printer Tool Box won't open and give me my ink levels
It could be the drive has become corrupted and should be reloaded, but to see ink levels all you have to do is to go to settings, and right click on the one you want to see, in order to display its properties.
SOURCE: brother MFC-465CN printer Error code 51 unable to print
Usually this is caused by a foreign object or debris under the printhead path, or under where the printhead "parks."
Unplug the machine. Open the cover. Check the printhead path for little bits of paper, push pins, paperclips, staples etc. Note the location of the printhead.
If the printhead is at the far left, gently slide it towards the center (do not force it). Look carefully under where the printhead was stopped for debris. Use a flashlight if necessary.
Close the cover. Plug in the unit. Try again.
SOURCE: ip4870 canon printer error number
Try this link below
http://www.fixya.com/support/r9017204-resetting_ink_waste_absorber_error
I hope this helps
Regards
GM
