Tried resetting it by unplugging it for 15 minutes. Plugged it back in, waited a couple hours and checked it again. Does not seem to be working. The interior light is working. Is there anything else that I could check.
SOURCE: refrigerator buzzing for 10 seconds every 4 or 5 minutes
I think you hit it right on the head. The start device is likely bad and trys to start the compressor (but can't) and it then overheats. If this type has a small white box on the left side of the compressor, take it off and shake it to see if it makes noise and debris falls out. That's the culprit. One more thing though, if your compressor has a decal with a little blue indian head drawing on it the compressor is also dead, otherwise you can just change the start device out and you should be good to go! There's a kit that replaces that type start device, comes with a new start device and overload along with the proper jumpers, etc. and it's REAL easy to install by yourself.
SOURCE: Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
SOURCE: Maytag washer not reset after power outage
The magnetic switch was stuck due to power outage / contactor are spark connect the contactor stuck together .Magnetic switch to replace.
SOURCE: Freezer Problem
If it started to cool again the compressor was running. Check the condenser and make sure it is clean. Provide as much air movement through the garage as possible . 100 degrees is a high temperature to be operating a refrigerator in.
Thank you for your post, Cynthia!
Based off the information you have provided your Frigidaire freezer is not cooling properly and is now displaying the temperature of 56. It sounds like your freezer is not on, even though it has power the compressor is not turned on. I would suggest pressing either the down or up arrow three times within five seconds. That should power on your compressor and it should start cooling properly. I hope this is helpful and if you should need further assistance please feel free to reconnect. -Matt
