20 Most Recent
Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW) Questions & Answers
Freezer stopped after power outage
If the sides are hot, look at the defrost timer. Sounds like it has stopped running with the defrost elements on. The compressor has a safety switch on it that opens either if the compressor gets too hot or if it pulls too much current when starting. If your power flickered a lot before coming back on, that triggered the safety switch. Now that it's running normally, I wouldn't worry. The defrost timer is your problem now.
Doest seem to be freezing as solid as it should aspecial in door
Hello Linda, thank you for your post!
I understand that your Frigidaire freezer is not freezing properly. This could be an issue with your sealed system (which is compressor, condenser, drier, or tubing) or your control panel. The recommended temperature setting for your freezer is 0°F. It is also possible that this could be a miscommunication within the freezer and I would suggest performing a reset. You can perform a reset by disconnecting the power cord for at least ten minutes. If the reset does not help resolve your problem you need to contact a professional technician for proper diagnosis and repair. -Matt
Frost on the evaporator
watch this video I made. this is subzero with low level of freon (almost out). same situation on all refrigerators and freezers. you can see ice at the begging of evaporator. if there would be a little more freon evaporator might of frost up at the top might frost half of evap other half would be not even cold.
Why is door ajar alarm on when door is closed
Hello friend, thank you for your post!
I see that your door ajar alarm is going off when the door is closed to your Frigidaire freezer. It sounds like a possible issue with the control panel or switch. Let's perform a reset to your appliance to see if that will correct the issue. You can do that by disconnecting power from the appliance for roughly ten minutes. I hope this helps. -Matt
The lower half of the freezer is cold but not the top. There is no air blowing ou the top vent. What should I do?
Hello friend, thanks for your inquiry!
I understand that the top of your Frigidaire freezer is not cold but the lower half is. I would recommend to perform a defrost on your freezer, I understand that it is a frost free freezer but it could be that maybe something has caused it to freezer over. You can perform a manual defrost by unplugging your appliance for four to six hours. If that is unsuccessful and you are still not getting cooler temperature up top I would seek assistance from a professional to come out and diagnose your appliance. -Matt
Red alarm light flashing
Good Morning Friend, thank you for allowing me to assist you!
Did your freezer previously experience a power loss? If the temperature of food rises to an unsafe level, the buzzer will sound and the red light, if equipped, will also glow. First, deactivate the alarm to your freezer by unplugging it or flipping the household circuit breaker. It is good to wait approximately ten minutes and then turn on your freezer. After deactivating the alarm and your freezer has run approximately four hours, the red light/alarm should go off on its own. If the red light/alarm continues to stay on, your freezer may possibly have a communication problem with the control board, temperature control or a wiring harness. If this is the case, I would recommend connecting with an experienced technician to determine the underlying cause. - Z
