My mistake, purchased in 2009 not 1993.
SOURCE: Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
SOURCE: Frigidaire upright--
2 months old should still be under warenty.
Check the freezer fan by opening the freezer door and pressing the door switch and listing for the freezer fan sound. If no sound then the fan motor could be bad.
Look at the back wall too see if you have frost build up. If you do then you have a defrost problem.
If thees are not your problem you could have a seal system problem. (( freon leak ))
SOURCE: Sears Ken Elite upright freezer model no 25329082991 temp alarm
alarm should go off when freezer reaches minus 18c or lower.
SOURCE: Frigidaire upright freezer-Model # LFFH2067DW. twice
http://www.searspartsdirect.com/partsdirect/part-number/Frigidaire-Parts/Freezer-Parts/297216600/0046/253/Model-LFFH2067DW7/1428/0142000?keySuffixId=NA&productTypeId=0142000&searchModelNumber=LFFH2067DW7&subCompDesc=System&brandDesc=FRIGIDAIRE&modelDesc=FREEZER&blt=11
Thermostat is what I would suspect first.
The defrost timer is the next suspect : http://www.searspartsdirect.com/partsdirect/part-number/Frigidaire-Parts/Freezer-Parts/297216600/0046/253/Model-LFFH2067DW7/1428/0142000?keySuffixId=NA&productTypeId=0142000&searchModelNumber=LFFH2067DW7&subCompDesc=System&brandDesc=FRIGIDAIRE&modelDesc=FREEZER&blt=11
I think the defrost heater is probably okay and it is just getting the wrong signals from the above components. But it is item 14 on this diagram: http://www.searspartsdirect.com/partsdirect/part-model/Frigidaire-Parts/Freezer-Parts/Model-LFFH2067DW7/1428/0142000/R0805140/00003
